Author Topic: Broken the Skudo again  (Read 9035 times)
Taxi_Driver
Re: Broken the Skudo again
« Reply #30 on: 13 December 2011, 18:20:45 »
 >:(  Well that didn't last long  >:(
2 weeks and approx 3k miles  :o
The new turbo that got fitted has failed with exactkly the same fault as the old one  >:(
The shaft that the blades are attached to has snapped.  >:(
Another new turbo ordered and should arrive tomorrow.....
« Reply #31 on: 13 December 2011, 22:43:45 »
Try not to drop it on the garage floor before you fit it :P
tidla
  • solihull
« Reply #32 on: 13 December 2011, 23:01:20 »
find a new garage.
oil feed and oil pressure to the turbo needs to be checked. waste of time chucking on a new turbo with no lube.
turbo pressure could of been checked without changing dpfs with a simple squeeze of a turbo hose.
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #33 on: 13 December 2011, 23:11:01 »
As said, this is not a Turbo problem, but a pressure one I should think.  If the pressure problems are not sorted, you'll be without a van every fortnight.
I believe the engines are Fiat derived?  Bloody good Diesel lumps!
Taxi_Driver
« Reply #34 on: 14 December 2011, 06:06:26 »
find a new garage.
Oil is getting to the turbo.....theres a 'bleed' valve on the turbo.....this was undo before the knackered one was taken off.....oil pissed out went everywhere
Taxi_Driver
« Reply #35 on: 14 December 2011, 06:09:04 »
Its a Pug lump......as is the whole bus.....i think
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #36 on: 14 December 2011, 10:42:52 »
The pug lumps don't normally suffer with turbo failures unlike renault's finest
other rides
« Reply #37 on: 14 December 2011, 22:15:43 »
All together now.....ow yes they do!
There not as good as the Pug diesels of 15 years ago
« Reply #38 on: 15 December 2011, 00:41:02 »
That seems to apply to most modern diesels :'(
Between the performance expectations and the emmissions demands, they seem to be getting less and less reliable :-\
A colleague used to run a 51 plate Ford Tourneo, did nearly 600k on original engine and still going, His 08 replacement, bought from new, had to have a new lump at 120k. :o
henryd
  • west cornwall
« Reply #39 on: 15 December 2011, 09:35:31 »
My 406 has done 200k miles and runs as well as ever,ex taxi as well :o
other rides
« Reply #40 on: 15 December 2011, 10:26:41 »
That all? Someone wasn't really trying then.  ::) Mine's been off the road for 10 of the 33 months that I've had it and inspite of that 200k is the next service 8)
henryd
  • west cornwall
« Reply #41 on: 15 December 2011, 12:00:51 »
This is Cornwall though,where is there to go !! ;D
other rides
« Reply #42 on: 15 December 2011, 12:11:12 »
There's a whole country (or three) out here :P
« Reply #43 on: 15 December 2011, 14:26:01 »
I currently have a Turbo off one here in bits.
Its a standard Garret variable geo turbo and the exhaust shaft seal has failed.
henryd
  • west cornwall
« Reply #44 on: 15 December 2011, 15:19:18 »
I've done many VW's,Audi's and Renaults but yet to have done PSA turbo,just been lucky I guess,206Hdi looks a barsteward to do :o
other rides
Pages: 1 2 [3] 4  All   Go Up
