Pages: 1 2 [3]  All   Go Down
Author Topic: Lemforder Wishbones  (Read 8033 times)
Re: Lemforder Wishbones
« Reply #30 on: 25 October 2011, 10:33:23 »
When replacing wishbones is it suggested to renew the bolts/nuts or just reuse existing?
It is "suggested" somewhere to replace the wb bolts. But not considered necessary. Lemforder wb's come with steering knuckle nut and bolt, and nuts for wb bolts. But not the wb bolts themselves. Never replaced the bolts myself.
« Reply #31 on: 25 October 2011, 13:52:34 »
Read through your guide Chris, I have trouble visualising some parts, could do wit some pictures I feel. I'm ok at drop links, disc / calliper removal, its after that i'm going to have trouble
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #32 on: 25 October 2011, 14:44:30 »
But regardless, for long term ownership, lemforder then Polly when the main bush fails....or before.
Unless you have a press. Then press new rearward.
Lemforder are worth it for not having to press, and give the best possible rearward bush, and a new ball joint.
Polly are worth it purely on the grounds of not having to break about tightening bolts wheels loaded.
Not cheap in total. But for best results long term.....
....IMO of course.
Shame to sacrifice new front bushes but it's so much easier if you fit the poly's first so that you don't end up laying on your back, on the floor, wedging the front bush hole clear of its hanger so that you can saw through the outer shell  ::), or is it just me getting old.  :(
Regards
Alan
« Reply #33 on: 25 October 2011, 20:37:02 »
I'm sure The fat pasty will guide you T. ;) he's got his own to do I believe? Follow him maybe?
« Reply #34 on: 25 October 2011, 20:44:02 »
....IMO of course.
Regards
Alan
Yep. All depends on rear bush and if preserving camber setting.
Tunnie has fubar rear bushes, and the camber setting is lost. Plus cash is an issue. And it's arguable if he'll notice any benefit from polly. So suggested fit lemforders, or whatever. But as camber is lost he can remove the steering knuckle to make fitting easier.
Then when the front bush fails or he finds a performance issue, he can fit polly.... Or someone can. ::)
« Reply #35 on: 25 October 2011, 21:12:02 »
I wouldn't bother with lemforder wishbones, not worth the money  ;D
YZ250
« Reply #36 on: 25 October 2011, 21:15:31 »
....IMO of course.
Shame to sacrifice new front bushes but it's so much easier if you fit the poly's first so that you don't end up laying on your back, on the floor, wedging the front bush hole clear of its hanger so that you can saw through the outer shell  ::), or is it just me getting old:(
Regards
Alan
 ;D ;D ;D Is that 'Yep' it's easier off the car or 'Yep' I'm getting old?  ;D ;D :y   Agree it does seem a waste to not get the use out of the new wishbone before eventually going down the poly front bush route.  :y
Regards
Alan
« Reply #37 on: 25 October 2011, 21:29:34 »
Speaking from personal experience ... Yep to both. ;)
Pages: 1 2 [3]  All   Go Up
