Pages: 1 [2] 3  All   Go Down
Author Topic: tunnies 3.2 project (pic heavy)  (Read 7057 times)
Re: tunnies 3.2 project (pic heavy)
« Reply #15 on: 23 October 2011, 16:51:36 »
soak it in Plusgas?
joshwyatt
  • Oxford
« Reply #16 on: 23 October 2011, 16:55:58 »
The springs are self levelling one's made by Boge, fitted at 54,000.
Yep, I'll be here next weekend  :y
Your both welcome to come over...or I can come to you?
« Reply #17 on: 23 October 2011, 16:57:09 »
soak it in Plusgas?
No harm, the sensor is knackered (we hope) anyway.  Really, really hope its not the wiring.
« Reply #18 on: 23 October 2011, 16:57:54 »
Don't mind, out of interest, do you have any self levelling rear shocks?
« Reply #19 on: 23 October 2011, 16:58:14 »
soak it in Plusgas?
Hopefully AutoAddict will remind us his lamda problems...
« Reply #20 on: 23 October 2011, 16:59:10 »
soak it in Plusgas?
What if we plugged them the other way around? (swap pre-cat to cat) Should prove if its loom issue?
« Reply #21 on: 23 October 2011, 17:00:03 »
I like it  :y
« Reply #22 on: 23 October 2011, 17:04:37 »
soak it in Plusgas?
You wont see it flick rich/lean, as post cat sensor should always read lean.
If the loom reaches, heat the car up (essential), then swap the front sensor lamdas over. If faults moves, according to engine ecu, to drivers side, it has to be sensor :y
You could tell this from pedal trick (if more codes beyond the ones there now appear)
« Reply #23 on: 23 October 2011, 17:06:27 »
I can't see it reaching  :(
« Reply #24 on: 23 October 2011, 17:27:34 »
I like it  :y
Tell you what, bodywork wise and underneath, its a corker. Could do with a wash and polish, but even with body plastics off, its so good.
Doorcards are messy, and a few 'soft touch' peels inside, but a superb base to start a 'keeper' project from :y
« Reply #25 on: 23 October 2011, 17:30:07 »
the car is in very good condition Tunnie.. :y
« Reply #26 on: 23 October 2011, 17:31:32 »
If your starting off with excellent bodywork everything else is possible. :y
« Reply #27 on: 23 October 2011, 17:45:28 »
A great project indeed - well done to all concerned. 8) :y
Taxi_Driver
« Reply #28 on: 23 October 2011, 18:30:04 »
Nice looking project there tunnie  :y
BTW you could have used brake cleaner on the sticky mess left by the tints as long as you spray it on a cloth first and use carefully so it doesnt come into contact with rubber, but if it does make sure you have a bucket of soapy water handy, so you can wash it off straight away  :y
I've used brake cleaner to remove the sticky mess left behind after removing stick-on advertising signs stuck on door panels.......once i'd got the mess off, i just washed the doors down.....the paintwork didnt get affected  :y
« Reply #29 on: 23 October 2011, 18:34:24 »
nice little tip there, might have to do that  :y
Pages: 1 [2] 3  All   Go Up
