Pages: 1 [2] 3  All   Go Down
Author Topic: Thankyou chrisgixer  (Read 7860 times)
Re: Thankyou chrisgixer
« Reply #15 on: 23 October 2011, 22:50:03 »
Thanks MrsG  :y
They were bullying me  :'(
Your all welcome for the curry, could not have got the 3.2 to the stage it is without all of your help.  :y
I've had curries before on TB, so it was my turn to get one  :)
You ok next Saturday for Wishbones? I'm going to order standard springs too, but I can fit those.
Sorry mate, we're away that weekend.
5th is the bucks meet
That'll be another curry then  ::) ::) ::)
Very kind. Thanks LD.
Home made so SWMBO can partake too. It's different ;) Not "Hot" but spicy and flavoursome :y :y Chicken OK or would you prefer Lamb?
« Reply #16 on: 23 October 2011, 22:50:27 »
Thanks MrsG  :y
Keep him taking him for them, fact I can call them fat is my only pi$$ take!  ;D
« Reply #17 on: 23 October 2011, 22:50:46 »
And, of course, loads of crisps :y :y
« Reply #18 on: 23 October 2011, 22:51:23 »
Next Sat is 29th, I'm back the Friday 28th as well. Wonder if little fatty is around, I can strip most of it down...
It's just fitting wishbones yes? No ploys.... Yet? 13mil socket method for camber. Place your ramps under the jacked wheels, put fatty in the drivers seet, torque the wb bolts. Check all bolts, away you go. :)
« Reply #19 on: 23 October 2011, 22:51:53 »
Thanks MrsG  :y
And you need all the ammo you can get :-X :-X  ;D ;D
« Reply #20 on: 23 October 2011, 22:52:55 »
yeah no Poly's yet, not if its new wishbones. Will Poly once they are shagged, which could be some time with my driving.
« Reply #21 on: 23 October 2011, 22:53:52 »
Thanks MrsG  :y
lovely job. Chicken? Either is fine.  :-*
« Reply #22 on: 23 October 2011, 22:54:27 »
Thanks MrsG  :y
Fact I have 6 cylinders is no good, they will just take the mick on my suspension setup. I should point out that their extra err "ballast" is the need for stiffer setup!  ;D
« Reply #23 on: 23 October 2011, 22:56:56 »
Should be piece of piss as your camber is lost. So just undo the shock and fit the steering knuckle to the steering pin, then fit the knuckle to the shock rather than battle levering the wishbone down to line the pin up.
« Reply #24 on: 23 October 2011, 22:58:21 »
Thanks MrsG  :y
I beg to differ... I need a stiffer setup on mine and I'm... Actually, perhaps it is ::) :D
Still can't decide if it's the inside wheel unloading that causes it so spin up or that the tyres are just not as good as they appeared :-\ :-\
« Reply #25 on: 23 October 2011, 22:59:45 »
Cheers, what could go wrong? Its only me :)
« Reply #26 on: 23 October 2011, 23:00:35 »
You running those dodgy TDFs from the Saab garage, LD?
« Reply #27 on: 23 October 2011, 23:01:55 »
.... Actually, no, leave it! Or get TB to help.
« Reply #28 on: 23 October 2011, 23:04:39 »
Neuton's... Yep, but only on the rear. Needed 2 rear tyres ASAP and the normal cheap ones I use weren't available ::)
Wasn't prepared to pay top dollar at the time for a couple of reasons, one of which is the planned upgrade of all suspension components in the near future ;)
« Reply #29 on: 23 October 2011, 23:05:24 »
Probably be safer :-X :P ::)
Pages: 1 [2] 3  All   Go Up
Page created in 0.09 seconds with 20 queries.
