Author Topic: dti heater plug question  (Read 7780 times)
daves omega
  • kilkenny, ireland
« on: 23 October 2011, 21:43:40 »
hello all iv a 2000 2.0 dti mega b and is hard to start in the mornings or when its after bein lying up for a while, it starts fine when below 3 degrees as thats when the heater plugs kick in, but in mild weather its hard to start, taght it was` getting air locked so changes seals and pipes but to no avail. was wondering can anyone tell me if there was a way to progam the heater plugs to come on every time u start it no matter the temperature. cheers  :)
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: dti heater plug question
« Reply #1 on: 24 October 2011, 17:23:35 »
do you have a primer pump fitted if so check that for leaks.
Solar charger fitted.
If not Broke dont fix it..
Rob Folland
  • belfast
« Reply #2 on: 25 October 2011, 06:56:08 »
I bought a hot start fix box on ebay works fine car starts first time every time, The box over-rides the temp sensor in the pump so heaters work on every start-up. My 2.2dti had the same problems as yours has
Clarkey
  • Ireland
    • 01 3.2 Auto Executive
« Reply #3 on: 25 October 2011, 13:49:57 »
Heater plugs work for every start up on that engine AFAIK. They also stay on for approx 2 mins afterglow after startup. It's just when temp is colder it puts heater light on dash to give more time before startup. Would have suspected air leak causing fuel to run back to tank.
daves omega
  • kilkenny, ireland
« Reply #4 on: 26 October 2011, 19:03:13 »
yeah have hand primer fitted and its not leaking from anywere, that was my first taught air leaking in and fuel returning to tank but if it starts perfect after heater light comes on, so if like clarkey said that they come on every start up i think its time to replace glow plugs. was looking at them hot start fix on ebay, are they handy to fit rob.
Rob Folland
  • belfast
« Reply #5 on: 28 October 2011, 19:21:20 »
Dave i got a local spark to fit mine took 10mins goes in the fuse box soldered to 3 wires works fine if you leave the heater light on for a couple of seconds
fergy
  • Hereford
  • 2001 CDX 2.2dti Estate
« Reply #6 on: 31 October 2011, 20:00:28 »
Hi
I had exactly the same difficulty on my car at about 115k. Eventually changed the glow plug control module which fixed it completely.
This is located in the triangular plastic box near your right wing as you look at the engine bay from in front. Now done 160k and all has been fine since, summer and winter.
Vauxhall Part Number GM 55354141
Understood to be fitted to:
Corsa C; 2001-2006: with Y17DT, Y17DTL engine code.
Sintra; 1997-1999: with X22DTH engine code.
Vectra 1996-2002: with X20DTL, X20DTH, Y20DTH, Y20DTR engine code.
Astra G; 1998-2004: with X17DTL, X20DTL, Y20DTL engine code.
Zafira A; 1998-2004: with X17DTL, X20DTL, Y20DTL engine code.
Frontera B; 1999-2004: with X22DTH, Y22DTH engine code.
Meriva with Y17DT, Z17DTH engine code.
Omega; 1994-2003: with X20DTH, Y22DTH engine code
daves omega
  • kilkenny, ireland
« Reply #7 on: 02 November 2011, 10:01:40 »
sounds good to me fergy, was thinkin it could have been the module, what sort of problems did u come accross with ur one fergy ?
fergy
  • Hereford
« Reply #8 on: 03 November 2011, 00:04:51 »
To add a bit more detail to my glow plug problem:
 Car would start well after  pre heat in cold weather. Car would crank for some time and eventually start when much warmer. It would also then kick out blue (un burnt diesel) smoke in copious quantities. The thing that I really noticed that had changed (with the fault) was that somewhere in between v. cold and v warm starting, the heater tell tale light would come on very briefly and then go out followed by an easy start up. With the module faulty, this changed to no brief heating period and poor starting. Best starting performance, with the fault was probably at about minus 2 or more. New module restored it all. Was about £50 from main dealer but could risk a used one for less?
 Other Dti problems:
Injector leak off pipes  -  poor starting
Crankshaft pulley  -  disintegrates at about 100k- its a bu%*er to get the retaining bolt off
Vacuum pipes split  -  rubber connectors split and  plastic vacuum pipe pinched  - EML light on, limp mode, Critical system fault.
EGR valve sticking- eml light on, normally intermittently but predictably- mine responded well to cleaning twice!
Prone to pump failure but I have been lucky so far,  fuel filter changed regularly though.
Sepentine belt tensioner and retaining bolt. -  Belt squeak on starting or when applying full steering lock. Can be changed without removing any other parts. Change fixing bolt at same time if you don't want it to sheer off a week later ! Also causes low  system voltage fault code on repeated short runs
Other than those points it is a brilliant car! Mine is used as a van in my business it does 20-50 miles every day  through traffic, is currently returning 43.5 mpg  and is far better than a transit despite having a little less performance than a new transit!
Page created in 0.024 seconds with 20 queries.
