Author Topic: Lots & lots of fault codes!!!  (Read 3694 times)
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
Re: Lots & lots of fault codes!!!
« Reply #15 on: 05 November 2011, 23:34:09 »
as said above have you sorted
brimmed with oil & water.
sounds like to me that the camcover gaskets are shot usually due to the breather system being blocked up, if you dont do this the you will knack the coil packs again  :(
« Reply #16 on: 06 November 2011, 01:17:10 »
Oil on plug wells, fit vx only cam cover o rings and seals, and clean the breathers, as the guide.
Water in plug wells, check wind screen seal is clipped on correctly, investigate possible leaking scuttle with a hose pipe or similar.
