Pages: 1 2 [3]  All   Go Down
Author Topic: Brake squeal.  (Read 5867 times)
Re: Brake squeal.
« Reply #30 on: 26 October 2011, 18:20:56 »
Grip has started to go with 452's on the rear of mine, 912's on front are better, but at 37k miles out of the front, not wear rate i have come to expect!  ;D
Think as mine are 16's and low power, that makes a difference to 17's and a V6.
I'd put them on again my 2.2, no doubt, but with 3.2 I opted for the as yet un-tested Nexen N6000s
Re: Brake squeal.
« Reply #31 on: 26 October 2011, 18:59:32 »
Might want to order a set of tyres before you kill that set, TB..
I think its likely these tyres will kill me first.
Re: Brake squeal.
« Reply #32 on: 26 October 2011, 19:00:49 »
Gripped well enough in dry when i drove it? Although really feking loud buggers, not sure I could live with that noise!
Re: Brake squeal.
« Reply #33 on: 26 October 2011, 19:05:59 »
Thats because you use Falkens normally ;)
Re: Brake squeal.
« Reply #34 on: 26 October 2011, 19:08:23 »
How fast do you want to drive, did 80 down that road to Radstone in yours  :o
Re: Brake squeal.
« Reply #35 on: 26 October 2011, 19:13:46 »
No issues at 80mph in a straight line in the dry. Slowing down or changing direction is where the issues lie.  In the wet, any speed, just accept you are going to die.
I'd rather have a Michelin than that Autogrip. Hence needing access to your garage to get another wheel ;)
Re: Brake squeal.
« Reply #36 on: 26 October 2011, 19:14:32 »
You find that ok? Its it a bit of a mess in there  :(
Re: Brake squeal.
« Reply #37 on: 26 October 2011, 19:16:24 »
Yes, thanks.
Not fitted yet, so I class the Elite as off-the-road again.
Re: Brake squeal.
« Reply #38 on: 26 October 2011, 19:20:17 »
If you need the Elite on-road, you could borrow the Nexens? As long as I get it back with most of the thread still on it  ::)
Pages: 1 2 [3]  All   Go Up
