Author Topic: Plenum Bolts Torque  (Read 7768 times)
Re: Plenum Bolts Torque
« Reply #45 on: 27 October 2011, 16:10:21 »
Well as my internet was down during my refit >:(,and I didnt have the benefit of the knowledgeable ones advise :y I have torqued them down to 20nm which seemed consistant with the injector manifold and sandwich plate. :D
In the real world, it's unlikely to do any harm  :y
« Reply #46 on: 27 October 2011, 18:08:33 »
Like it or not, the official value is 8Nm.
Its just tight enough to seal the 6 o rings, without crushing them to buggery
« Reply #47 on: 27 October 2011, 18:36:46 »
Are you of the opinion that tightening them beyond that could damage the rings then TB?
« Reply #48 on: 27 October 2011, 18:55:44 »
How can the o rings be crushed or damaged? They sit in a grove designed for that diameter o ring. Its not possible to crush them unless an o ring is unseated and gets trapped.
All the bolts have to do is compress the rubber to seal until the plenum is tight to the manifold. That takes 8nm to achieve. Any more is over tight for the purpose of squashing the o rings, obviously a bolt that size will take more, as will the thread in the inlet fanimould, although I would think that's the week point.
IMO just do em up, making sure the o rings remain seated correctly while locating the pegs. Far more important than a couple of "nums".
4 pages, Lordy!
Oh, I can believe the cam shaft caps are 8nm either. But they are! :)
« Reply #49 on: 27 October 2011, 19:05:01 »
Not in the short term.
Given the depths of the grooves, probably not in the long term either.
amba
  • Medway towns
    • German V6
« Reply #50 on: 27 October 2011, 20:54:05 »
So after 4 pages  ;D ;D ;D the definitive answer is 8nm  :y ; but if they were torqued down to 20nm that would still be fine  ;D :y
Anyway that is what I have done mine to  :)
« Reply #51 on: 27 October 2011, 21:04:29 »
split the difference with 14 ........  ::) ::) ;D ;D
amba
  • Medway towns
    • German V6
« Reply #52 on: 27 October 2011, 22:14:39 »
Perhaps it would be nearer that with the accuracy of some torque wrenches  ;D ;D
Pages: 1 2 3 [4]  All   Go Up
