Author Topic: interior lights  (Read 2994 times)
pauls
  • By the sea minehead
    • Bmw x3
interior lights
« on: 28 October 2011, 21:24:11 »
Hi i have posted this before but cant find it. None of my interior lights work. Since posting this question i have checked the following fuses 7,12,20 no good.  Has anybody got any help please.
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: interior lights
« Reply #1 on: 31 October 2011, 19:31:22 »
check the light switch control  its in the head light switch, check that it lights up at night with out turning on the lights should be on at top alltime when ignishion is on.
Solar charger fitted.
If not Broke dont fix it..
pauls
    • Bmw x3
Re: interior lights
« Reply #2 on: 31 October 2011, 20:38:49 »
Just a update. Puddle lights dont work neither do there work when you pull out the switch for the headlights :(
freecall666
Re: interior lights
« Reply #3 on: 31 October 2011, 23:26:44 »
cannot remember think they just fused with relay, i know on mine when drivers door is open all 5 lights come on meaning centre and doors but pass side opens only dose front lights, and a back doors opens only dose the back doors but thats because there is two light realys some one fitted before got the car, they stay on till time gose out or the key is turned in ignition, is ther anthing ells not working like cig lighter etc?
pauls
    • Bmw x3
Re: interior lights
« Reply #4 on: 01 November 2011, 18:47:13 »
Hi checked the rest of car cig lighter works no lights on vanity mirror. Would a faulty bulb cause this. Because i cant find a blown fuse..
freecall666
Re: interior lights
« Reply #5 on: 01 November 2011, 23:34:55 »
no only thing can think is to take the fuse box out and check the wires on the back, have you had the dash out or anthing before this happend?
Re: interior lights
« Reply #6 on: 01 November 2011, 23:41:27 »
Have you actually removed them to check?  :-\ :-\
pauls
    • Bmw x3
Re: interior lights
« Reply #7 on: 02 November 2011, 10:40:32 »
Hi just to answer your questions yes I took the fuses out to make sure not broken. No I havnt had the dash out. it was a case of 1 day it worked the next day it didnt. I dont no where to go from here.
cheers
Paul..
freecall666
Re: interior lights
« Reply #8 on: 02 November 2011, 20:31:34 »
take one of the door bulb light s out and use a meter to see if there is volts using a good earth from some were ells, do same on others  just see if there is volts may be a bad earth.
pauls
    • Bmw x3
Re: interior lights
« Reply #9 on: 03 November 2011, 21:42:38 »
Sorted the problem. Turned out my mistake it was a blown number 7 fuse. This was due to a loose wire that was behind the drivers sunblind. Anyway thanks for all your help.
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
Re: interior lights
« Reply #10 on: 03 November 2011, 21:43:40 »
well done  :y
freecall666
Re: interior lights
« Reply #11 on: 03 November 2011, 22:04:09 »
