Author Topic: TD fuel consumption  (Read 8891 times)
GmasterT
  • Cambridge
  • does that drifting thing...
Re: TD fuel consumption
« Reply #15 on: 30 October 2011, 13:33:30 »
Check for shite on the intercooler/fan, good indication is if the fuse has popped under the bonnet relays :)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #16 on: 31 October 2011, 13:20:32 »
Thanks to both last posters. I'll check the fuse, and hopefully get the live data checked soon. :y :y :y
Shackeng
  • Ramsbury
« Reply #17 on: 01 November 2011, 14:05:31 »
Right, I've checked all the 30A fuses are OK in the relay box. How/where do I access the intercooler fan to check it? Although I guess it must be working if the fuse is OK.
« Reply #18 on: 01 November 2011, 14:27:23 »
with that kind of consumption, i'd want a V6 under my right foot  :o
Shackeng
  • Ramsbury
« Reply #19 on: 01 November 2011, 15:23:29 »
Got a 3.2 one of those as well, which is doing about the same!
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #20 on: 01 November 2011, 17:27:09 »
It's hidden by the front end of the O/S/F wheel-arch liner ;)
Shackeng
  • Ramsbury
« Reply #21 on: 01 November 2011, 17:58:20 »
Thanks Byron, is that accessed by removing the wheel arch?
Seth
« Reply #22 on: 01 November 2011, 18:29:31 »
Yes, so I'm reliably informed! ;)
« Reply #23 on: 01 November 2011, 18:30:57 »
The intercooler won't affect consumption (well, not by much).  Worth getting the I/C fan working for other reasons (and keep it working by dumping the viscous).
« Reply #24 on: 01 November 2011, 18:32:17 »
Remove the rubber cowling, unplug the fan (vital!!), turn the blades by hand a couple of dozen times, then connect it to 12v for a hour, occasionally lubricting the bearing
Shackeng
  • Ramsbury
« Reply #25 on: 01 November 2011, 18:43:52 »
 Presumably accessed via the O/S wheel arch as per Seth's post :y
« Reply #26 on: 01 November 2011, 18:46:50 »
Personally, I'd drop the bumper off, much easier :y
But, yes, behind the bumper, just in front of wheelarch liner, drivers side...
Shackeng
  • Ramsbury
« Reply #27 on: 01 November 2011, 18:52:43 »
Thanks J., it'll have to wait a bit now due a hand operation tomorrow. >:(
GmasterT
  • Cambridge
« Reply #28 on: 04 November 2011, 08:21:31 »
Dunno, I unleashed about 5mpg on clearing mine, was pretty clogged though
[/quote]
[/quote]
Agreed, bumper off :)
Shackeng
  • Ramsbury
« Reply #29 on: 04 November 2011, 09:49:22 »
Thanks GM, I'll have a go when the stitches are out :y :y :y
Pages: 1 [2] 3 4  All   Go Up
