Author Topic: Wet carpet passenger Rear  (Read 3624 times)
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
Re: Wet carpet passenger Rear
« Reply #15 on: 24 November 2011, 22:45:52 »
if you have a sunroof check the drains for that  :y
also under the car for any holes  ;)
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #16 on: 25 November 2011, 21:22:50 »
Did you read my earlier post on windscreen leak
PAULCDX
« Reply #17 on: 25 November 2011, 22:41:05 »
Yes mate, I'm gonna look into that side of things. Just confused as to why it's only the nearside rear footwell carpet that is getting wet??
Everytime I lift up the mat, the carpet is soaking wet.......... Can't see any leaks from the ceiling or any water on the doors, seats, or coming from near the sunroof....
Cheers for your help.
fiend61
  • york
  • each to their own
« Reply #18 on: 25 November 2011, 23:09:26 »
if sunroof drains are blocked wont the water run down the centre pillars? (where seatbelts are)  sorry dont know the pillars name  :-[
« Reply #19 on: 25 November 2011, 23:36:24 »
Rear door seal possibly ? :-\
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #20 on: 26 November 2011, 10:56:08 »
I thought you said that the front carpet was wet as well On mine and I suspect yours the water was coming in through the  windscreen into the front well and then running to the back well get you screen seal  checked
PAULCDX
« Reply #21 on: 26 November 2011, 12:58:01 »
At first it appeared to be front and rear nearside but just lately it only seems to be the nearside rear thats still getting wet??? Confused lol, cant seem to find where the water is coming in. The carpet is wet mainly by where the rubber mats fix down to the floor and in the centre of the floor if that makes sense?? :(
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #22 on: 26 November 2011, 14:47:43 »
There is a depression in the floor near the outer sill and the water runs down this from the front to the back therefore untill a lot of water is present the front carpet stays faily dry
