Author Topic: exhaust manifold gasket  (Read 2516 times)
millwall
  • se london
  • no muff too tuff
    • accord type s
« on: 31 October 2011, 21:04:44 »
going to do mine tomorrow  the bolts have had plenty of plus gas  but is it better to do it cold or run the engine to get some heat on the bolts
Re: exhaust manifold gasket
« Reply #1 on: 31 October 2011, 21:44:06 »
Cold will be fine, not realy had any issue with post 1997 motors (they changed a few bits then)
millwall
  • se london
  • no muff too tuff
    • accord type s
« Reply #2 on: 31 October 2011, 21:50:16 »
thanks mark :y
amba
  • Medway towns
    • German V6
« Reply #3 on: 31 October 2011, 22:19:54 »
Drivers side or Passenger ??
Will be in Keston all day so will listen out for any bad language then ::)....post up some piccies  ;D as need to do my drivers side and curious as to how you deal with the access to the transfer pipe to back of block. ;D ;D
Best of luck then  :y
millwall
  • se london
  • no muff too tuff
    • accord type s
« Reply #4 on: 31 October 2011, 22:39:48 »
hopefully wont be too much bad language ;D ;D  luckily its on my vectra so easy access :y
amba
  • Medway towns
    • German V6
« Reply #5 on: 31 October 2011, 22:54:21 »
Best of luck anyway  :y
millwall
  • se london
  • no muff too tuff
    • accord type s
« Reply #6 on: 31 October 2011, 23:10:55 »
millwall
  • se london
  • no muff too tuff
    • accord type s
« Reply #7 on: 01 November 2011, 16:01:12 »
job done took all of 30 mins  no dramas all bolts came off easy  thanks to plus gas ;D  very easy engine to work on lots of room   and the end result no more tapping sounds and blow when first started from cold :)
« Reply #8 on: 01 November 2011, 16:02:07 »
Clearly not an Omega V6 then  ;D
millwall
  • se london
  • no muff too tuff
    • accord type s
« Reply #9 on: 02 November 2011, 17:02:02 »
if it was a v6 it would have stayed as it was ;D ;D
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #10 on: 03 November 2011, 17:35:04 »
I have a theory that it may be possible or even easier to remove the manifolds from underneath the car if up on a ramp.  A theory I intend to put to test one day soon.  When the cats were off last I did manage to get my hands to all the nuts quite easily although it was a case of feeling rather than having eyes on at the same time.
I have some 2.6 manifolds here willing themselves to be put on the car  ::)
