Author Topic: Auto box problem!!  (Read 2141 times)
Blackie_No1
  • Ballyclare N.Ireland
    • Omega Elite 2.5
Auto box problem!!
« on: 02 November 2011, 11:31:38 »
So there I was happily driving along on Thursday when the engine suddenly seemed to be bouncing up and down the revs all by itself!! Like it was trying to find a gear.
I nursed it home jacked it up and it seemed a little low on gearbox oil (don't worry I checked the level with the engine running), so I topped it up.
Took it out for a drive and it decided it would dump all of the oil out through the breather pipe!!
I left it in with a guy I know who fixes Vauxhalls and he threw a replacement auto box in for £300 including fitting and she seems to be as ggod as new!
ANyone else have a similar problem?
2000 Omega Elite 2.5 V6
Re: Auto box problem!!
« Reply #1 on: 02 November 2011, 11:37:26 »
Its a pity your not over here, I could have saved you £100 :D  Glad its sorted though :y
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
« Reply #2 on: 02 November 2011, 12:50:13 »
A lot of similar experiences posted on here in past - usual format is ATF change/top up, possible crank sensor, possible solenoid etc but you have got yours sorted for not too much money. Warning though - sometimes after this type of problem has occurred it may then not reappear for ages. At least if you get a repeat then it maybe crank sensor.
Blackie_No1
    • Omega Elite 2.5
« Reply #3 on: 02 November 2011, 17:23:18 »
You have got me intrigued, why would the crank sensor cause the box to spit out its oil?
pscocoa
« Reply #4 on: 02 November 2011, 17:54:23 »
I was referring to the first problem of an apparent neutral position/ no gear selected which can be as a result of engine speed /autobox miscommunication - and which can of course be the crank sensor.
« Reply #5 on: 02 November 2011, 22:20:08 »
300 notes is reasonable enough for a gearbox fitted for you :y
Blackie_No1
    • Omega Elite 2.5
« Reply #6 on: 03 November 2011, 08:21:45 »
Ah!!!! I see now batman!
