Author Topic: Which brakes?  (Read 1543 times)
Which brakes?
« on: 02 November 2011, 13:07:37 »
I have a 02, 2002 3.2 MV6
What brake discs to I need (size) on the front - and what pads?
I can see the Calipers are stamped Lucas if that helps. I understand there are two different types, I don't want the wrong ones!
Cheers,
James
Re: Which brakes?
« Reply #1 on: 02 November 2011, 13:20:31 »
Discs & pads on TC are
93175466  £111.00  £91.63  £81.62
bored bigyin54
  • south wales
    • black beast
Re: Which brakes?
« Reply #2 on: 02 November 2011, 13:25:12 »
that makes a change for james to be on here lol
Re: Which brakes?
« Reply #3 on: 02 November 2011, 15:43:21 »
Does the 3.2 MV6 have 286mm discs or 296mm discs on the front? Or, does it Vary?  :-\
Re: Which brakes?
« Reply #4 on: 02 November 2011, 16:16:58 »
Only 4 pots have the smaller size and non vented(might just be the 8 valve)
V engines(and all other engines) all have larger and vented discs. Dealer should be able to I.D.
Re: Which brakes?
« Reply #5 on: 02 November 2011, 16:43:38 »
PMFL, then it`s 296mm across the range, all front discs are vented
Re: Which brakes?
« Reply #6 on: 02 November 2011, 18:54:37 »
 :y :y
Re: Which brakes?
« Reply #7 on: 02 November 2011, 19:42:32 »
The dealer with give you the right ones.
Don't fit pattern discs. They are universally shite. Been there, done that, was even stupid enough to do it again.
GM discs last me about 3yrs, pattern discs last me a week or 2 at most (although I spend a lot of time in Milton Keynes)
Re: Which brakes?
« Reply #8 on: 02 November 2011, 20:56:49 »
even a well known brand such as mintex, TB?
Re: Which brakes?
« Reply #9 on: 02 November 2011, 20:58:05 »
Just as cheap to buy Trade Club discs & pads as a set.
Re: Which brakes?
« Reply #10 on: 02 November 2011, 20:59:25 »
Mintex make cheap junk ;)
Shimmy
  • St Albans
    • Omega 3.2 Elite
Re: Which brakes?
« Reply #11 on: 02 November 2011, 21:00:25 »
Brakes and tyres are things I'd never skimp on.
Brakes are cheap enough anyway, especially with a trade card.
Budget tyres, false economy.
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: Which brakes?
« Reply #12 on: 02 November 2011, 21:02:13 »
Genuine Vx discs with EBC Green Stuff pads are the specified choice here! :y
Page created in 0.036 seconds with 16 queries.
