Author Topic: Ccrt700 head unit replacement  (Read 2701 times)
ALLYMV6
  • Dungannon N.Ireland
    • Mv6 omega
« on: 08 November 2011, 23:26:55 »
Hi guys, just new to the site and hopefully someone can help me out here. I've recently bought a 99 mv6 with a ccrt700 head unit. I have removed it and replaced it with a pioneer deh 6300 which was in my previous omega. The head unit is doing all the right things but there is no sound. Would this have something to do with the audio system that's in this car?!!!! Cheers
THE ONLY WAY FORWARD IS SIDEWAYS
Re: Ccrt700 head unit replacement
« Reply #1 on: 09 November 2011, 00:13:35 »
I'd guess the CCRT was probably Bose enabled. Is there Bose in the car? If so the aftermarket HU won't be compatible ;)
« Reply #2 on: 09 November 2011, 00:27:17 »
Amp and speakers will need to be replaced - Bose is 2 ohm. ;)
ALLYMV6
    • Mv6 omega
« Reply #3 on: 09 November 2011, 10:34:52 »
Have took a quick look to see if Bose is stamped anywhere but don't see it. How can I tell if it is that system?!!!!
« Reply #4 on: 09 November 2011, 10:48:29 »
If saloon, speakers on rear shelf with amp underneath. Estate, amp in o/s cubby hole in load area, speaker, n/s cubby hole
ALLYMV6
    • Mv6 omega
« Reply #5 on: 09 November 2011, 12:03:56 »
Did look under shelf and there is no speakers or amp, there is just the wiring loom for it taped up underneath. So does this mean that the pioneer should operate in the car?!!!!
« Reply #6 on: 09 November 2011, 18:43:25 »
Is the Piioneer a known working unit? Or new?
ALLYMV6
    • Mv6 omega
« Reply #7 on: 09 November 2011, 20:05:15 »
YEAH THE HEAD UNIT WAS IN MY LAST CAR AND WORKING FINE. THIS IS HEAD WRECKING :(
« Reply #8 on: 09 November 2011, 20:12:30 »
If its a non bose car, there is nothing incompatible.
Is the adapter between the car loom and the stereo the right one?  Guess your stereo just needs 3 power lines, the 8 connections for the speakers, and the aerial......
ALLYMV6
    • Mv6 omega
« Reply #9 on: 09 November 2011, 22:02:20 »
i will take the stereo out and try it in another car just to make sure the volume is working but i cant see anything different from my last omega which was also an mv6 which had no phone or sat nav
ALLYMV6
    • Mv6 omega
« Reply #10 on: 10 November 2011, 20:52:39 »
hey guys got the pioneer problem sorted. there is no bose system in the car and i plugged the hu into another car and it was the same problem so i took the cheap option first and got a new wiring harness for the hu and plugged it in and now its up and running, HAPPY DAYS :y. BIG THANKS for those who give me the different options.
