Author Topic: TID Upgrade  (Read 5506 times)
TID Upgrade
« on: 09 November 2011, 21:13:44 »
The BC features are all based around a speed pulse from the ABS and a fuel use signal from Engine ECU.
Check control is individual signals in.
All the above is built into Omega display.
Can the TID be upgraded to include trip computer funtctions without a factory HU?
If 'Yes', what would be required?
Al. :y
Re: TID Upgrade
« Reply #1 on: 09 November 2011, 21:14:59 »
Yes.
MID, a new wiper stalk, and a bit of wiring (mostly around fooling check control)
Re: TID Upgrade
« Reply #2 on: 09 November 2011, 21:22:24 »
Ok :y.
So would the MID come from a CD or CDX and need pairing (to the ECU presumably) :-\
And would the loom from donor car suffice?
Could the GID be used instead?
Re: TID Upgrade
« Reply #3 on: 09 November 2011, 21:26:14 »
MID needs to come from a similar engine/gearbox/HID car (else well need Tech2).  No pairing.  Grey plug one would be better due to better reliability.
GID - no, that won't float your boat.
Re: TID Upgrade
« Reply #4 on: 09 November 2011, 21:32:17 »
I likes a challenge... ::) 2.6 manual CDX :-\
CID then?
Re: TID Upgrade
« Reply #5 on: 09 November 2011, 21:47:32 »
CID then?
Errr, NO!
GID and CID need NCDx HU...
Re: TID Upgrade
« Reply #6 on: 09 November 2011, 21:52:33 »
Oh ok. ::)
Mud cleared.
Will a CDX suffice for the parts/loom?
Re: TID Upgrade
« Reply #7 on: 09 November 2011, 21:54:11 »
Oh ok. ::)
Mud cleared.
Yours is 3.2?  No CDX was 3.2 ;)
But any MID (can be reprogrammed), and a suitable wiper stalk with S and R buttons.  Wiring is minimal TBH.
Re: TID Upgrade
« Reply #8 on: 09 November 2011, 21:58:07 »
Was thinking a 2.6, but no matter if it needs programming anyways. :y
Suspect that the stalk will plug straight in, as the car seems to have most of the wiring for all the toys that the 3.2 would normally have :-\
Re: TID Upgrade
« Reply #9 on: 09 November 2011, 22:00:49 »
If you're *really* lucky, you'll have the wiring from stalk to MID, but no hassle if you dont - all easy peasy stuff :y
Until you get MID reprogrammed, the MPG/Range etc will be rubbish.
You won't get Check Control to work, so you have to do wiring changes to fool the MID into thinking these sensors are good
Re: TID Upgrade
« Reply #10 on: 09 November 2011, 22:04:18 »
What is it lacking then?
Re: TID Upgrade
« Reply #11 on: 09 November 2011, 22:07:15 »
Sump level sensor.
Coolant Level Sensor
Washer Level Sensor
Brake Pad Sensor
Bulb monitoring
I think.
Re: TID Upgrade
« Reply #12 on: 10 November 2011, 00:01:23 »
Sump level sensor.  :-\
Coolant Level Sensor Check
Washer Level Sensor Check
Brake Pad Sensor Check
Bulb monitoring :-\
I think.
Lots of finger and toe crossing... ::)
kcl
  • Finland
    • Volvo V60 D4 -14
Re: TID Upgrade
« Reply #13 on: 10 November 2011, 11:28:12 »
Sump level sensor.
Washer Level Sensor
Brake Pad Sensor
Bulb monitoring
I think.
Pad sensor is present even if the car has TID, will illuminate relevant light below the display  :y
Coolant level: wires are there, you just need a new bottle with sensor
Washer level: the same BUT you can fit only the sensor to existing bottle (I think...)
Sump level sensor would require sump removal and dunno of the wiring.
Bulb monitoring is the trickiest part as you should put the CheckControl unit to your car and that might require some serious wiring
Re: TID Upgrade
« Reply #14 on: 10 November 2011, 12:57:23 »
Where does the check control module live?
Think that sump level might be the one other piece of the puzzle that is missing. Don't recall any stray wiring there aboots :-\
Brake pad wire certainly there, connected to thin air at mo (just to keep light off as clip busted) ::).
A couple of days forced hols next week, so may go rummaging. :y
