Author Topic: Is there a towbar wiring How-To...  (Read 12275 times)
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
Re: Is there a towbar wiring How-To...
« Reply #15 on: 22 November 2011, 10:27:16 »
Is there anything else I have missed, while I'm at it
umm the caravan twiglet ????  ;D ;D ;D ;D ;D
twiglet
  • Norwich, Norfolk
« Reply #16 on: 22 November 2011, 10:31:06 »
Doughnut!!  ::) :P ;D
fiend61
  • york
  • each to their own
« Reply #17 on: 22 November 2011, 10:33:22 »
doughnuts hmmmmmmmmmmmmmmm (drool)  ;D ;D ;D ;D
« Reply #18 on: 22 November 2011, 14:23:19 »
Cheers Andy  :y
Right, I'm getting there...
So to get the warning light on the dash working, I need to fit a bulb and change the flasher unit for a 4-pin jobbie.  Would I be right in thinking that I need an RFL6 as shown here...
http://www.vehicle-wiring-products.eu/VWP-onlinestore/relays/flashers.php ... correct?
To get the brakelight failiure to check the caravan lights, I need to plug in relay part no. 90463123 up behind the glovebox... correct?
The 12S socket will be wired through a self switching split charge relay like this...
http://www.ebay.co.uk/itm/12V-30AMP-SPLIT-CHARGE-RELAY-KIT-SELF-SWITCHING-/200677814285?pt=UK_Campervan_Caravan_Accessories&hash=item2eb954700d ... is this the one to go for?
Is there anything else I have missed, while I'm at it?  :y
It looks to be Yes on both accounts. I bought mine from Halfords, ISTR I only had a choice of one 4 pin relay. Your local towbar 'specialist' will have a voltage senstive relay on the shelf.  :y :y
DaveA
  • Leicestershire
    • Insignia CDTI SE 160
« Reply #19 on: 29 November 2011, 17:57:59 »
   Been following this thread, it prompted me to fit the four pin flasher relay and the repeater light in the dash and get rid of the beeper, which at times was driving me mad.
   When my tow bar was fitted (Vauxhall dealer) they spliced into the wiring loom. Now if I fitted a brake light check relay, would it work wired up this way.
    The reason I ask is that people keep mentioning that there is a plug behind the spare wheel by the rear left light cluster, I've looked, even used a mirror to look under the wing but I cannot find it :-[ :'(
  Don't want to pinch the thread but is my Mig different from every other ;) ;)
Regards
    Dave
DaveA
  • Leicestershire
« Reply #20 on: 29 November 2011, 17:59:00 »
Made a mess of this ignore this post  >:( >:(
« Last Edit: 29 November 2011, 18:02:25 by DaveA »
Regards
    Dave
« Reply #21 on: 29 November 2011, 18:11:01 »
The plug should middle-ish of the trim at the rear ege of the boot. It's a square 9 pin including a feed for your caravan's fridge/charging supplied by a fuse under the steering column.
DaveA
  • Leicestershire
« Reply #22 on: 29 November 2011, 18:17:18 »
Thanks Andy been looking in the wrong place :y
Regards
    Dave
Jack-V6
  • Netherland
    • omega Y2.5DTI 2003
    • opel omega portal
« Reply #23 on: 29 November 2011, 19:46:20 »
Why do you have 2 contact boxes and why not a single 13 pin? Is there a special reason.
Find it ugly too have two of those things under my bumper. even hate the 1 I have under my car.
I would like anyone on attacks but just curious.
Gr Jack
« Reply #24 on: 29 November 2011, 21:39:51 »
Gr Jack
For some strange reason, in the UK when we added the 12S socket years ago as rear fog lights were added to cars & nicked the feed from the 12N socket that used to be used for the caravan's fridge &/or charging, we seemed to stall & not progress from that. The 12S isn't the best of sockets either, it's not uncommon to find the pin suppyling the fridge to burn out. While continental Europe progressed and came up with (various  ???) 13 pin sockets we didn't & kept 2 sockets.
We are catching up though, all new caravans now come with a 13 pin plug.  :y :y I have upgraded both my car & caravan.
A couple of years ago in France I offered my help to a Dutch man who had ripped his socket from his car, it was 13 pin, but different from mine. It had the old style round 12N pins in the middle & had flat spade connectors around the edge, presumably for his caravan's charging & fridge.
« Reply #25 on: 29 November 2011, 21:43:14 »
..... even hate the 1 I have under my car......
You need one of these then  ;) ;)
out of sight
in use
(rear bumper was removed for something else)
geoffr70
  • Sunderland
  • Boobies
    • F/L 3.0 Elite, 3.0 MV6
« Reply #26 on: 29 November 2011, 23:19:47 »
Someone provided this info for me when i did mine......
HTH
twiglet wants a second 12S grey socket for caravan battery charging & fridge ;) ;) ;)
Oh well, it didn't say that in the post, or post heading.  ;) ;) ;) :y
but in the third post down ......
as Andy has highlighted .....
all was explained .....
[/quote]
because I'll be damned if I can find it!
[/quote]
Bloody hell! You try to help someone in good faith and all you get is people trying to pick fault. It's quite common I've noticed. I can do a smiley face aswell  :y
Perhaps the first post should be a little more specific then.
TC and BnQ Trade holder.
Jack-V6
  • Netherland
    • opel omega portal
« Reply #27 on: 30 November 2011, 08:12:22 »
out of sight
in use
here we have three systems.
standard 7 pole
Jeager 13 plig
and Multicon feder 7 pin edge connectors for additional 8 to 13 This is what you saw on the Dutchman his car.
Multicon west is the same as above but has de additional pins more in the center instead on the edge.
Here is a link with all the connections for trailer couplings. It's in dutch
http://caravantrekker.nl/algemeen/stekkers.php
Gr Jack
