Author Topic: Temp Sensor on Zafira A  (Read 3036 times)
MutantCav
  • Gainsborough
« on: 11 November 2011, 22:52:14 »
The outside temp reading is saying 40-60 degrees cent...anyone know where the temp sensor is so I can move it away from the engine/heat source that is throwing it off...or replace it if its faulty??
Cheers :)
Re: Temp Sensor on Zafira A
« Reply #1 on: 11 November 2011, 23:26:33 »
Cheers :)
It's right in the middle of the lower section of an Astra G's bumper if that's any use, and the same sensor as the Omega's. I'm sure you'll find it if you  look.  ;) ;)
MutantCav
  • Gainsborough
« Reply #2 on: 12 November 2011, 22:48:11 »
Cheers Andy...never actually seen one on the many Omegas I have had but will certainly have a look :)
MutantCav
  • Gainsborough
« Reply #3 on: 18 November 2011, 16:33:15 »
As the temp is reading 40+ degrees with a cold engine on a cold day...would this mean the sensor is fubarred??
