Author Topic: Code reader.....Will it work?.  (Read 5437 times)
« on: 14 November 2011, 19:38:02 »
Will a code reader that works on my 53 plate MV6 also work on Mrs Opti's 53 plate Corsa?
If it does, it might be a wise investment. :y :y
Re: Code reader.....Will it work?.
« Reply #1 on: 14 November 2011, 19:46:11 »
Any EOBD reader should read the engine (only) ECUs.
« Reply #2 on: 14 November 2011, 20:02:33 »
Is that a yes, TB?........and what is an EOBD reader?
« Reply #3 on: 14 November 2011, 20:05:56 »
An EOBD (our version of the virtually identical OBDII) reader will work on all petrols registered after 2001, and all diesels registered after 2003, for Engine Only.
A Testbook (Rover's dedicated diags equipment), for example, won't be any use at all.
« Reply #4 on: 14 November 2011, 20:09:06 »
Thanks TB. And this clever money saving device will cost me......£....?
« Reply #5 on: 14 November 2011, 20:12:22 »
Varies.  About £40 for a generic one that requires a laptop, around £70 for the cheapest standalone, to several thousand for top of the range, more capable stuff.
To do all onboard systems, a Vauxhall specific device is required, such as Vauxcom, Opel Autoscanner or genuine Tech2. See FAQ.
« Reply #6 on: 14 November 2011, 20:14:37 »
Can someone supply a link for one of these, please?
  • Auckland
    • Mazda MPV
« Reply #7 on: 14 November 2011, 20:29:36 »
Google for Autel Maxiscan MS509
Amongst the results you will find one to this site  ;) and lots to sales sites.
Plenty of reports of dodgy clones being sold on ebay  :( ..........
« Reply #8 on: 14 November 2011, 20:32:00 »
Thanks, Andy. Will do. I presume this one will do the job.... :y :y
« Reply #9 on: 14 November 2011, 21:39:49 »
I have a MaxiScan MS509 (AFAIK a genuine one, certainly seems so anyway  :y) - very good recommendation. Works a treat on my 3.2 and should on the Corsa, neat live data, data capture, download to PC etc..
« Reply #10 on: 14 November 2011, 21:51:08 »
Roughly £50 on Ebay. But how can I tell a genuine from a fake?... :-\
« Reply #11 on: 14 November 2011, 21:57:33 »
I paid a bit more than that for mine - about £60 from 'mobile_ecu_remapping', but his prices have gone up quite a bit now: http://www.ebay.co.uk/itm/AUTEL-MAXISCAN-MS509-OBD2-ENGINE-FAULT-CODE-SCANNER-READER-TOOL-EOBD-MIL-LIGHT-/170707864020?pt=UK_Diagnostic_Tools_Equipment&hash=item27befb49d4#ht_2567wt_940
« Reply #12 on: 14 November 2011, 22:11:31 »
Thanks, Aaron. It might be worth paying the extra to make sure that I receive the genuine item. What does it cost to read the codes at a VX dealer. Any idea?... :y
« Reply #13 on: 14 November 2011, 22:12:37 »
I suspect the answer to that is "Whatever they think they can get away with" ;D I don't know, though - I wouldn't expect to get it done for less than £30 these days though :-\
woodoo
  • Heanor
  • www.woodoo.yolasite.com
    • Vauxhall Omega 2.0l Auto
« Reply #14 on: 14 November 2011, 22:16:06 »
edit : No discussing obtaining counterfit devices please
« Last Edit: 15 November 2011, 08:13:09 by Jimbob »
