Author Topic: V6 3.2 Aux Belt  (Read 2909 times)
V6 3.2 Aux Belt
« on: 15 November 2011, 10:58:01 »
Changing the belt, in the garage I have a brand new one. Bought some time ago, GM part number: 93181720.
Would this fit a 3.2?
Are all V6 aircon aux belts same size?
Thanks  :y
kcl
  • Finland
    • Volvo V60 D4 -14
Re: V6 3.2 Aux Belt
« Reply #1 on: 15 November 2011, 11:08:44 »
A quick Google visit gave this http://www.ekmpowershop2.com/ekmps/shops/vauxworld/0193181720--drive-belt--alternator-belt---calibra-cavailer-omega-sintra-vectra---new-part-1388-p.asp so I'd say yes, it will fit. And, as far as I know they're all the same (V6 with air con)
And, to confirm http://www.rmeuropean.com/Part-Number/Belt-6PK-X-2020-Single-Belt-Drive-__93181720_CON_1FAEF62B.aspx gives the correct length (2020)
Re: V6 3.2 Aux Belt
« Reply #2 on: 15 November 2011, 11:10:13 »
I think some very early V6s had a different pulley layout but chances are it'll be OK. Just try it. :y
kcl
  • Finland
    • Volvo V60 D4 -14
Re: V6 3.2 Aux Belt
« Reply #3 on: 15 November 2011, 11:12:33 »
Found this from a forum...  :D
Title: Re: 3.0 MV6 Fan Belt
Post by Pete Elite on 04. Sep 2009 at 23:36
Hi,
   My 96 3.0L Auto with Aircon uses the 93181720 and i would have thought that this should be the one for yours as well :-?.
I got the info. below from my EPC which doesn't even mention belt # 93181720 but instead 93181721 which I've highlighted:-?.
1  BELT,DRIVE,21.36 X 1900 MM,ALTERNATOR (IDENT FK) (NLS.- USE 9118618 OPEL 91126386VAUXHALL)
EXCEPT AIR CONDITIONING X25XE,X30X   1  90409782  13 40 742
2  BELT,DRIVE,21.36 X 1900 MM,ALTERNATOR (IDENT FW) (NLS.- USE 9118618 OPEL 91126386VAUXHALL)
EXCEPT AIR CONDITIONING X25XE,X30X -W1193599
1  90500228  13 40 614
4  BELT,DRIVE,21.36 X 1900 MM,ALTERNATOR (IDENT FX) (FOR DELETION OF AIR CONDITIONING PARTS) (FOR VAUXHALL) (NLS.- USE 93181719) X25XE,X30X W1193600-
1  91126386
7  BELT,DRIVE,21.36 X 2260 MM,ALTERNATOR (FOR JAPAN) (IDENT FX) (NLS.- USE 9118620) (SEE SERVICE INSTRUCTIONS)
USED WITH AIR CONDITIONING X25XE,X30X R1000001-S1059678
1  90500354  13 40 615
6  BELT,DRIVE,21.36 X 2020 MM,ALTERNATOR (IDENT AC) (USED WITH AIR CONDITIONING) (NLS.- USE 9118620) (EXCEPT VAUXHALL) X25XE,X30X S1059679-X1032987
1  90528761  18 54 728
6  BELT,DRIVE,21.36 X 2020 MM,ALTERNATOR (IDENT AC) (USED WITH AIR CONDITIONING) (NLS.- USE 91126388) (FOR VAUXHALL) X25XE,X30X S1059679-X1032987
9  BELT,DRIVE,21.36 X 2020 MM,ALTERNATOR (IDENT FX) (USED WITH AIR CONDITIONING) (FOR VAUXHALL) (NLS.- USE 93181721) X25XE,Y26SE,X30XE,Y32S X1032988-
1  91126388
10  ROLLER,TENSION (NLS.- USE 90528760) X25XE,X30X   1  90409783  13 40 536
10  ROLLER,TENSION (NLS.- USE 9202550) X25XE,Y26SE,X30XE,Y32S   1  90528760  13 40 547
10  ROLLER,TENSION X25XE,Y26SE,X30XE,Y32S   1  9202550  63 40 538
11  -PULLEY,TENSIONER X25XE,Y26SE,X30XE,Y32S   1  9157962  13 40 512
12  -SCREW,PULLEY,M10 X 30 X25XE,Y26SE,X30XE,Y32S   1  9157950  13 40 801
13  -NUT,PULLEY,M10 (NLS.- USE 12992580) X25XE,Y26SE,X30XE,Y32S   1  9157951  13 40 802
13  -NUT,PULLEY,M10 X25XE,Y26SE,X30XE,Y32S   1  12992580  13 40 832
14  -COVER,PROTECTION,TENSIONER X25XE,Y26SE,X30XE,Y32S   1  9157963  13 41 667
         HTH,
               Pete :).
  PS. It seems to me that both the belts that dbug has mentioned have had the last digit added to by 1 in the EPC that I've shown, Very odd :-?.
Re: V6 3.2 Aux Belt
« Reply #4 on: 15 November 2011, 11:36:25 »
Changing the belt, in the garage I have a brand new one. Bought some time ago, GM part number: 93181720.Would this fit a 3.2?
Thanks  :y
Fits all V6`s
Re: V6 3.2 Aux Belt
« Reply #5 on: 15 November 2011, 12:04:01 »
any tips for getting it on? tensioner pushed back as far as it would go, sooo close to getting on but cannot get it over top of the lip tensioner  :'(
dab of grease on tensioner lip & belt?
Re: V6 3.2 Aux Belt
« Reply #6 on: 15 November 2011, 12:09:35 »
Just a thought, warm belt in hot water? soften it?  :-\
Its so close to going on.
Re: V6 3.2 Aux Belt
« Reply #7 on: 15 November 2011, 12:13:52 »
DONT put grease on the belt or tensioner pulley !! - belt will slip and squeal like a pig.Put it over the water pump pulley last.No lip on that pulley. :y
Re: V6 3.2 Aux Belt
« Reply #8 on: 15 November 2011, 12:25:47 »
Albs you star!!!!!!!!!!!!!
Popped it on tensior first, that allowed me to use my breaker bar to release tension, which was so much easier. Slipped straight over water pump easy as pie on first go!
 :y  :y  :y  :y
kcl
  • Finland
    • Volvo V60 D4 -14
Re: V6 3.2 Aux Belt
« Reply #9 on: 15 November 2011, 12:27:58 »
 :y  :y  :y  :y
As it is described in the how - to. Please read the manual. Or, RTFHT  :y And, if there isn't one, it's been discussed here thorougly enough.
Re: V6 3.2 Aux Belt
« Reply #10 on: 15 November 2011, 12:31:34 »
 :y  :y  :y  :y
Think its part of cambelt one
Re: V6 3.2 Aux Belt
« Reply #11 on: 15 November 2011, 12:47:59 »
 :y  :y  :y  :y
After 16,000 posts I finally posted something useful - YAY !!!  ;D ;D ;D
Re: V6 3.2 Aux Belt
« Reply #12 on: 15 November 2011, 12:56:58 »
 :y  :y  :y  :y
Stop exaggerating Albs, you know very well you've only got 15984! ;D ;D ;)
Re: V6 3.2 Aux Belt
« Reply #13 on: 15 November 2011, 12:57:43 »
 :y  :y  :y  :y
I wholeheartedly concur with that statement :P
