Pages: 1 [2] 3  All   Go Down
Author Topic: A very scary experience on the road...  (Read 7260 times)
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
Re: A very scary experience on the road...
« Reply #15 on: 16 November 2011, 13:25:06 »
If the gearbox has possible known issues and given the fact that it went into limp mode before the thuds it does point to the autobox.  :-\  Add to this the unexplained whine, this has got to be a starting point for elimination. Even interrupted power would feel bad through the transmission though.
Reference the post below, amazingly this is not always the case with the diff. On one of my previous cars I ran with a badly chipped planet wheel (didn't know at the time) for over a year (over 8000 miles) and apart from the whine, it seldom went out of mesh, but when it did, it was scary. Felt like the back end was twisting. After about three massive juddery thuds it would settle down again and be good for many more miles. The diff oil was like glitter when I replaced it.  ;D
As said, mine was obvious lock up at back end so much easier to pinpoint, hence my question about diff whine. In your case, it does sound like the gearbox is first check though.
don't sound like a diff issue to me at all.
If something is worn so bad that it's come out of mesh, then it would undoubtedly bi in bits on hte floor having come through the casing. It would never rotate again.
definitely inside the transmission.
Hope you get it sorted soon.  :y
Regards
Alan
« Reply #16 on: 16 November 2011, 13:31:34 »
Is it worth dropping the oil out of the diff... I'd soon see if there were any lumps of metal, that way?
« Reply #17 on: 16 November 2011, 15:20:31 »
UPDATE
Used the car again this PM
Did 2 miles around town, seemed fine. Joined a dual carriageway. gave some revs to overtake again - and immediately, as soon as I eased off the gas, small thump, and into limp mode.
Stopped and restarted.
Same again - foot down, up to about 70mph - eased off, and boomf.. limp mode again.
Now totally stuck in limp mode.
My sealey code reader says a code is stored but won't tell me what. I might try with my er, other device, this evening, and see if I can gain anything from it.
Either way, do we think this is mechanical, or might I get away with a duff solenoid etc..  ::)
robmac
« Reply #18 on: 16 November 2011, 16:39:14 »
i had similar problems last week to those described and it turned out to be my crank sensor. new vauxhall one fitted and all good again.
YZ250
« Reply #19 on: 16 November 2011, 18:19:14 »
Would it be worth road testing it without using drive at all. Pull away in first, shift into second and third but avoid drive completely. This way the selector doesn't have to think as you are doing it for it. Might be worth a shot to see what happens. These things will do 128mph in third anyway so can't see it being a problem.  ;D
Regards
Alan
« Reply #20 on: 16 November 2011, 18:39:57 »
If the EML has come on, there will be a code stored in the engine ECU.  Might simply be a code to say check gearbox ECU.
BUT there will be a code.
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
« Reply #21 on: 16 November 2011, 19:33:51 »
i had similar symptons on my ar25 box.It eventually gave up the ghost,had gearbox code read via tech 2 at a vauxhall dealer to find the torque converter had failed :(
« Reply #22 on: 16 November 2011, 21:11:52 »
Engine fault codes as follows:
P1700 - Service Vehicle Soon Request from Transmission Control Module
 (08) - Present
Gearbox codes as follows:
P0748 - <Unknown DTC>
 (06) - Present
Drove her again, and upon acceleration, around 4-5000 rpm, car shuddered very violently, repetitively, as if the drive was being applied/released/applied/released, very quickly...
« Reply #23 on: 16 November 2011, 21:14:04 »
I believe the gearbox code is: Pressure control solinoid circuit open
Does this mean likely to be electrical, then?  :-\
« Reply #24 on: 16 November 2011, 21:56:42 »
Just looked at the diagram PDF in the images area, the pressure control solenoid appears to be in the FRONT smaller sump, towards the drivers side. So reasonably easily accessible.
Given this is the solenoid which it's complaining about, is it worth perhaps popping the front sump off, and changing this solenoid as a starter for ten? Or am I barking up the wrong tree there?
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
other rides
« Reply #26 on: 16 November 2011, 22:49:04 »
I would check the multiway connectors to the gearbox and also the 3 large connectors behind the battery first. Gearbox signals go through one of these and it's not impossible that it's loose.
Also check resistance between the pins on the gearbox ECU connector for this solenoid. I'm guessing you should see a few tens of ohms.
Then drop the front sump and see if anything's amiss.
« Reply #27 on: 16 November 2011, 23:07:55 »
believe there have been a couple of very similar faults posted in the last couple of months re those connectors giving that code. Might be worth a search James, and a check of the connectors of course.
« Reply #28 on: 16 November 2011, 23:13:42 »
many thanks gents :y
« Reply #29 on: 17 November 2011, 10:31:19 »
I've put a post in parts wanted, but, does anyone have an autobox lying around they would sell me a pressure control solenoid from, please? (Small / Easy to get to)
Failing that, I can get one new, delivered, for £46, but need to order before lunchtime to get for the weekend, and, need to do some other elimination first. But it would be really good to have one to hand  :-\
Pages: 1 [2] 3  All   Go Up
