Author Topic: interior Light  (Read 5796 times)
Re: interior Light
« Reply #15 on: 20 November 2011, 13:51:40 »
try changing headlamp bulbs in a vec-c  :o also when you start working on your car you will see how awkward vauxhall can be  ::)
Try a side light on a Smart Roadster  ;) ;) clicky
Re: interior Light
« Reply #16 on: 20 November 2011, 14:05:30 »
Like trying to do the main beam bulbs on the Nissan - four bolts on the underside of each lamp, airbox out to get at two of them (blind) and indicator out to ram your hand through and get to the other two (blind).. thank you Mr Nissan ;D
Kaycee
  • Doncaster
Re: interior Light
« Reply #17 on: 21 November 2011, 06:32:37 »
So in conclusion I have a interior light bulb out
What are the steps i need to take to change this bulb
if the light unit as to come out does it lever out to get to the bulbs if so is there a special way to avoid damage
Thank you
There is a tide in the affairs of man if taken at the flood will lead on to greater things
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
Re: interior Light
« Reply #18 on: 21 November 2011, 07:09:00 »
yes it is just clipped in gently lever out with screwdriver  :y
