Author Topic: Temp question .............  (Read 1781 times)
I_want_an_Omega
« on: 19 November 2011, 14:09:30 »
Ok, have finally got the opertating temp sorted on my Daughter's Corsa B 1.0 12v.
Turned out to be the thermostat - it's fine now with the new one and sits @ 92c which is spot on. You can see it open up/close etc on the warm-up and also the fan comes on when it gets hot. Sorted  :y
I also flushed the system and blanked off the EGR and filled the system with nice new Vx red coolant mixture.
My (long winded) question is whether sorting the temp out and blanking the EGR will improve the MPG. She does 10  miles to work and then home again. Only done 280 miles so far in the car but it got through most of a (45L) tank of fuel.  :(
I'm hoping that this will improve it significantly. The temp gauge previously never got off the end stop unless in heavy traffic when it would get to 92. The heater now get HOT, whereas before it was only warmish.
The car also had a full service just after we bought it, all except for the coolant/stat/EGR change which I did myself. The coolant flows through the EGR valve plate so it was necessary to drain the system to do that.
Comments please, thanks guys ........
Re: Temp question .............
« Reply #1 on: 19 November 2011, 14:11:07 »
working egr helps mpg ;)
Ken T
  • Stockport
« Reply #2 on: 19 November 2011, 14:23:43 »
I have noticed an improvement on my Mig mpg after replacing the stat. Only about 3-4% but there anyway.
Ken
I_want_an_Omega
« Reply #3 on: 19 November 2011, 15:45:08 »
Thanks - have just been out for a 20 mile drive, seems to be running better. Will see what the real world MPG is like after a week or so.
« Reply #4 on: 19 November 2011, 21:59:50 »
If the engine never got hot properly cos the 'stat was open then the car would have been  on 'choke' for much longer, the temp sensor would have told it to.  :y
I_want_an_Omega
« Reply #5 on: 19 November 2011, 23:10:18 »
If the engine never got hot properly cos the 'stat was open then the car would have been  on 'choke' for much longer, the temp sensor would have told it to:y
My thoughts exactly ........
2woody
  • Northumberland
« Reply #6 on: 21 November 2011, 14:38:15 »
Not including the "choke" effect mentioned above....
generally speaking, the hotter the mass coolant temperature the better the economy.
