Author Topic: How many gears???  (Read 2577 times)
maracus
  • Cambs
  • Hahaha cool- 1000+bhp combined on the drive!!!!!!!
    • 3.0mv6 auto, cav4x4 turbo
How many gears???
« on: 21 November 2011, 15:49:22 »
I thought these v6 autos were 4 speed?? It's just that I keep counting 5 shifts. Even if you lock into 3rd afterwards it'll go up then up again. It's deffo in third because if you slow and lock it down a gear until 1st it shifts each time.
Is there an overdrive or some sort of splitter?
Or can I not count?
The weather is here... Wish you were beautiful!
Re: How many gears???
« Reply #1 on: 21 November 2011, 15:52:00 »
Something to do with torque convertor lock out. Dont know much about it but an intelligent person will probably explain shortly. ;D :y
« Reply #2 on: 21 November 2011, 16:20:26 »
Yup - three speed with overdrive ('fourth' gear) IIRC, but the torque convertor locks up in 3rd and OD. Accelerate gently enough and you can count five 'shifts' - 1st to 2nd, 2nd to 3rd, lock in 3rd, unlock, 3rd to 4th, lock in 4th.
The shuffling in & out of lock at gentle throttle and up & down inclines is what makes the box seem like it's 'hunting' for a gear sometimes, as it can't change gear when the torque convertor is locked up, so you get: 4th with lock->unlock (revs go up)->3rd (revs go up again)->3rd with lock (revs go down)
maracus
  • Cambs
« Reply #3 on: 21 November 2011, 17:39:10 »
Ummm- eh?? What locks?? Why? It will probably make more sense when I read it again later..
So it goes from a sloppy fluid connection to a solid locked connection???
I'm confused!!
« Reply #4 on: 21 November 2011, 17:41:59 »
I'm confused!!
Yup
« Reply #5 on: 21 November 2011, 17:42:19 »
Precisely that - at certain points (basically when the 'load' on the gearbox is low, or you're cruising at a steady speed) the two halves of the torque convertor will be physically locked together; so it behaves like a conventional clutch rather than a hydraulic coupling.
A physical connection is much more efficient than turning x% of the engine power into heat by churning the ATF up in the torque convertor  :y
« Reply #6 on: 21 November 2011, 17:44:21 »
???  4th gear is the "lock-up"
« Reply #7 on: 21 November 2011, 17:48:46 »
That goes against what I've read here, previously?  Maybe I just misunderstood what I read.
« Reply #8 on: 21 November 2011, 17:56:44 »
Quote from the resident gearbox guru Sassanach
 "4th" gear IS the tc locking up.i am not aware of it locking in "3rd",please enlighten!   :)
« Reply #9 on: 21 November 2011, 18:05:27 »
AR35 is the 4L30-E, no?
It seems you're right that it doesn't lock up in 3rd, at least according to this bulletin: http://www.transtec.com/downloads/rebuilder_news/4th_q95r-n.pdf (page 5)
But both that and this say it has 4 speeds, not 3: http://www.transtec.com/downloads/rebuilder_news/2nd_q95r-n.pdf
Elsewhere I read that it's a 3-speed box (rear casing) with an additional overdrive (front casing) and lockable torque convertor (TC housing): http://www.unofficialbmw.com/images/BMW_Automatic_4L30E.pdf
http://scottj.info/files/isuzu/4l30e.pdf (another random PDF I found while trying desperately to find the first two ;D)
« Reply #10 on: 21 November 2011, 18:10:11 »
I make that six. :-\ ::) ;D
« Reply #11 on: 21 November 2011, 18:11:28 »
I never said maths was my strong point.. ;D although we just decided it doesn't lock the TC in 3rd, so now we're down to four. ;D
« Reply #12 on: 21 November 2011, 18:15:08 »
It is indeed the old 3 speed box with an overdrive unit bolted on the front (thus 2 sumps). 4 speed. Except for post 2001 Opel diesels, which are 5 speed.
The lockup is software controlled, and there are 3 main ECU types (ignoring the 5 speed one we don't have in the UK), each with varying software levels, so its feasible some may lock up in 3rd  :-\
« Reply #13 on: 21 November 2011, 20:29:36 »
Mine certainly locks up in 3rd. And 2nd if you get the autobox fluid really hot. :-X
It does have 4 discrete gear ratios plus TC lockup.
maracus
  • Cambs
« Reply #14 on: 21 November 2011, 21:40:33 »
Thanks for that people, confusion solved!! Sorry I missed the conversation I got otherwise distracted.. I will have a read of those links so I can tell others how it works  :y :y
