Author Topic: Testing 2013.  (Read 2291 times)
Testing 2013.
« on: 22 November 2011, 17:50:28 »
I have a complete Bose setup - 2013 with mono screen,amp,loom ariel,speakers. After carrying out a repair I want to test the HU and screen to make sure all funcions work as they should.Im thinking I can connect all the components to each other and will then just need to supply power ? If so where do I connect the + and - to on the HU and amp ?
Tia. :y
Re: Testing 2013.
« Reply #1 on: 23 November 2011, 12:29:57 »
Anyone ? :-\
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
Re: Testing 2013.
« Reply #2 on: 23 November 2011, 12:43:00 »
sorry albs dont know if this will help scroll right to bottom  :-\
http://teletehnika.km.ru/articles.php@id=174
Re: Testing 2013.
« Reply #3 on: 23 November 2011, 14:14:26 »
You would need to supply power to head unit, display, aerial preamp and amp and make the connections between these items so you'd need the various bits of Omega loom to make up a test harness.
Might as well just install them in an Omega, TBH, unless it's something you need to set yourself up to do on a regular basis. ;)
Re: Testing 2013.
« Reply #4 on: 23 November 2011, 14:39:03 »
Might be easier to pay Twiglet a visit and plug it into one of his elites then. ;) ;D
I know I can plug the HU into my CD,but I want to test the whole thing for full functionality.
Re: Testing 2013.
« Reply #5 on: 23 November 2011, 14:50:27 »
If you get one with a CID, you're welcome to come and plug it into mine to 'test' it.. ;) :-* :-* ;D
    • 530D M Sport, 330i Coupe
Re: Testing 2013.
« Reply #6 on: 23 November 2011, 15:11:00 »
If you were closer you could use my test loom....  ::)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Testing 2013.
« Reply #7 on: 23 November 2011, 15:49:40 »
More info and pinouts by pm Albs.
Chris.
Re: Testing 2013.
« Reply #8 on: 23 November 2011, 18:07:22 »
Recieved Chris,thanks.And thanks to everyone else for the replies. :y
