Author Topic: Relays Wanted.  (Read 2944 times)
P6UL K
  • Dartford, Kent
    • Vauxhall Omega 3.0 Elite
Relays Wanted.
« on: 22 November 2011, 18:50:39 »
Going on from this thread... http://www.omegaowners.com/forum/index.php?topic=94515.msg1183904#msg1183904
I'm after the 3 relays that are situated up above the fuse box on the drivers side and their colours are Red, Yellow & Green.
Ta  :y
Re: Relays Wanted.
« Reply #1 on: 22 November 2011, 18:58:55 »
Pretty certain I have them in the shed Paul.Will check in the morning and let you know for definite. :y
P6UL K
  • Dartford, Kent
Re: Relays Wanted.
« Reply #2 on: 22 November 2011, 19:04:10 »
Smashing - Cheers Alb  ;)
Re: Relays Wanted.
« Reply #3 on: 23 November 2011, 11:58:36 »
I have two of the yellow and two of the green relays Paul but no red one.Possibly not all cars were fitted with the red one ?
Do you know what the red one is for ? :-\..........or got a part number for it.I have several orange/brown coloured relays (which I dont think are the correct one) but no reds,apart from servotronic relays and they live in the other side of the car.
P6UL K
  • Dartford, Kent
Re: Relays Wanted.
« Reply #4 on: 23 November 2011, 23:43:54 »
I'll try and get a look when i can over the weekend mate, i'm racing all day at Brands on Sat.
Re: Relays Wanted.
« Reply #5 on: 24 November 2011, 00:44:47 »
OK. If you need a yellow and a green I can post them as soon as you let me know. will need your address again though as I didnt keep it last time.
P6UL K
  • Dartford, Kent
Re: Relays Wanted.
« Reply #6 on: 02 December 2011, 19:02:34 »
Albs has a green and yellow relay for me, anyone have a red one fron under the steering column?
Re: Relays Wanted.
« Reply #7 on: 03 December 2011, 10:40:35 »
Servotronic ECU IIRC. It's on the driver's side on later facelifts.
Re: Relays Wanted.
« Reply #8 on: 03 December 2011, 10:42:40 »
Ah,that explains it.I couldnt think of another red relay on the car,but thought they always lived in the passenger side. :y
Re: Relays Wanted.
« Reply #9 on: 03 December 2011, 10:47:06 »
Kevin - do you know,of the top of your head what the green and yellow relays are for ? :-\
Paul - as these two and not the red one seem to be the problem, try replacing them and see if it helps.The red servotronic relay is expensive even second hand. Iirc they are at least £80 from VX. I do have one but I doubt you will need it, as you havent mentioned having any problems with the PAS. :y
P6UL K
  • Dartford, Kent
Re: Relays Wanted.
« Reply #10 on: 03 December 2011, 19:16:18 »
A wealth of information as expected Albs/Kevin  ;) ;D :y
I'll do that Albs and see how i get on from there, but yes your correct - No steering issues (yet lol)
Re: Relays Wanted.
« Reply #11 on: 03 December 2011, 19:21:33 »
Posted 1st class this morning Paul,should be with you Monday. :y
P6UL K
  • Dartford, Kent
Re: Relays Wanted.
« Reply #12 on: 03 December 2011, 19:28:15 »
Amazing!  8)
Re: Relays Wanted.
« Reply #13 on: 03 December 2011, 19:30:30 »
No, just Royal Mail. :D ;D
