Pages: 1 2 [3]  All   Go Down
Author Topic: Brand new CID tech2 programming ?  (Read 12532 times)
Re: Brand new CID tech2 programming ?
« Reply #30 on: 10 January 2012, 18:59:25 »
Seen it before when you cannot get the tech2 to talk to NCDC.  Usually pulling the NCDC out for a couple of hours cures this.  But rare.
omegafin
  • xxx
« Reply #31 on: 10 January 2012, 19:38:40 »
Pulling radio out is not same than disconnetcting battery for 2 hours ?
But they got the Bose logo programmed I have thought that its is shown only when radio is programmed to Bose-mode
so the radio's output levels are set right for Bose amp. So they have maneged to connect Radio then ??
Or can logo be programmed without connection to radio ?
« Last Edit: 10 January 2012, 19:40:54 by omegafin »
« Reply #32 on: 10 January 2012, 19:47:23 »
The Bose logo is when you programm the CID for Bose. The radio is programmed seperately.
omegafin
  • xxx
« Reply #33 on: 14 January 2012, 14:16:01 »
I got "My Naff Code Reader" and tried to connect to radio , cid , cd  an gps :
Radio : pin 7 first but tries other pins too - no connect
cd :pin 7 first but tries other pins too - no connect
gps : pin 8 first but tries other pins too - no connect
CID  : pin 8 connect OK , in delivery mode , id: 24459629,1599,1201,0707,046,1
i think the first is cid's GM number but old and new is 24439378 why ?
then gives fault 191-can bus max config - list not present
I will remove the Radio for a day,  when I find my Radio removal tools .....
« Reply #34 on: 14 January 2012, 14:39:54 »
Radio - Pin 7
CD - Pin 7
Display - Pin 8
(there is no GPS module for this setup)
I've seen the CD (NCDx setups only) go a bit wonky on the diagnostics line, stopping comms with *anything* on the same diags line, such as Engine ECU.  Oddly enough, often after "My Naff Code Reader" has been talking to it.
Cure seems to be removal of CD changer for a while (so pulling out the stereo in your case for a couple of hours).
To be honest, "My Naff Code Reader" seems a bit dangerous with NCDC setup, probably best avoided. Best kept away from key programming for similar reasons as well. Stick to dealer equipment for these tasks.
omegafin
  • xxx
« Reply #35 on: 14 January 2012, 14:46:28 »
Radio - Pin 7
CD - Pin 7
Display - Pin 8
If i remember right I managed to connect vai pin 7 to elect. air con ? first i thought that pin 7 is loose from diagconnector
I won't use "My Naff Code Reader" for programming for sure , too risky .
but now i see fault codes and when radio wakes up.....
what is the 191 fault code ??????
« Last Edit: 14 January 2012, 14:54:39 by omegafin »
« Reply #36 on: 14 January 2012, 14:49:41 »
Radio - Pin 7
CD - Pin 7
Display - Pin 8
Misconfigured.
omegafin
  • xxx
« Reply #37 on: 24 January 2012, 16:18:37 »
I removed the radio and think I found the fault  :y
Diag crimp terminal in radio cage is too deep or bent somehow so it won't connect to radio.
( Looks brown in pic upper plug , mid row , 3 from left )
So how I remove the metal cage and where to get new crimp terminal ? this is smaller than normal iso terminals.
http://imageshack.us/photo/my-images/96/24012012031b.jpg/
« Reply #38 on: 24 January 2012, 20:57:35 »
Its a standard size, and decent car stereo place should stock.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #39 on: 24 January 2012, 23:04:33 »
If asking at a local car audio shop, the smaller pins at the top are referred to as "Mini ISO" unlike the larger pins in the middle and bottom that are "Standard ISO"
Shout if you are still struggling for pins, as I will be having another delivery at the end of the month
Radio & Decoding Technician
www.dndservices.co.uk
Pages: 1 2 [3]  All   Go Up
