Author Topic: Unbelieveable!!  (Read 2339 times)
Taxi_Driver
Re: Unbelieveable!!
« Reply #15 on: 14 March 2008, 21:50:18 »
They shouldn't be using a bloody airtool on the crank in the first place!
Bunch of rather monkeys.
BTW Mark........what is a 'harmony wheel', I heard its summat to stop vibration? .......is this just on diesels? If so do all diesels have them?
And would you expect one to disentigrate on a 53 plate vectraC 106k miles on it??  :-/
Re: Unbelieveable!!
« Reply #16 on: 15 March 2008, 00:23:46 »
Not a harmonic damper, was it? (AKA crank pulley)
Taxi_Driver
Re: Unbelieveable!!
« Reply #17 on: 15 March 2008, 07:27:29 »
Dunno......my m8 said vx called it a harmony wheel......ive never heard of anything like that.....so could be anything.......dont think if crank pulley broke youd still be able to drive it......which he could. :-/
Re: Unbelieveable!!
« Reply #18 on: 15 March 2008, 08:14:29 »
A harmony (as in hairspray, was it a bird?) damper is a description by somebody who doesn't know what the hell they are talking about, a harmonic damper I could of accepted. The correct title is crankshaft ribbed V belt pulley which is part of the auxiliary aggregate drive
Here is the TIS extract for removal:
Rotate engine 90°
52.   Release crankshaft ribbed V-belt pulley (1)
Note:   2nd mechanic is required
•   Use KM-977-1 or KM-6619 (2) together with KM-956-1
KM-977-1 up to MY 2003 and engine number 17K44148
KM-6619 from MY 2003 and engine number 17K44149 onwards
•   Loosen bolt
•   Remove KM-977-1 or KM-6619 and KM-956-1
You will note the requirement for two mechanics and no mention of any airtools. The two special tools mentioned are two bloody great big levers, one that holds the pulley and the other that connects to the crank bolt.
So the bottom line is, they have tried to cut a corner, failed, buggered some tools up, charged him for it and then done it by the book. I suspect the grease gibbon has bunged it in gear and bunged an air hammer on bolt......and you shouldn;t do that to the likes of cranks which have end float settings and spacers/bearings
Interestingly, I would expect the pulley bolt to round long before any decent quality tool was damaged.
