Pages: 1 2 [3]  All   Go Down
Author Topic: Another quality TheBoy production...  (Read 4709 times)
Re: Another quality TheBoy production...
« Reply #30 on: 14 March 2008, 22:11:29 »
i think i`ll just sit in the corner with me coke and packet of cheese an onion crisps..i`m still none the wiser :-[
do you mind if i share with you......
looks clever but bugger me if i know what it does
EPROM = Electronic Programmable Read Only Memory...is that right???
PROM - Programmable Read Only Memory
EPROM - Erasable Programmable Read Only Memory (normally UV light to erase, hence window on such chips)
EEPROM - Electrically Erasable PROM
Technically this programmer is for EEPROMS.
So that heap of wires is for putting new software and/or data (eg, fuel map) onto one of the Omega ECUs ::)
Matchless
  • Nottingham
    • A white van
« Reply #31 on: 14 March 2008, 22:23:56 »
TB, You should have used a professional Electronics Engineer to build that for you. I happen to know of a couple that are shortly to be out of work.
PS, you missed the Write Only Memory as invented by Burroughs.
    • 530D M Sport, 330i Coupe
« Reply #32 on: 14 March 2008, 22:37:57 »
Now there's a blast from the past, I started in IT working for a third party maintenance company who's Director and most of the engineers were X Borroughs / Sperry / Convergent Tech / Unisys engineers.... I've spent many hours (usually early hours of the morning!) messing about with A5 and A10 Mainframes  ::)
HerefordElite
  • Hereford
  • Welcome to the Shire
« Reply #33 on: 14 March 2008, 23:05:50 »
whats that do then?
Programs EPROMS.
 ;D ;D ;D ;D ;D ;D ;D ;D
pmsl
« Reply #34 on: 14 March 2008, 23:59:35 »
That's too good for landfill.
Chuck it up into a tree. It's nearly spring. Something's bound to nest in it!  ;D
Well, that ain't going to program a 27c256, so it's not the MV6's map. :-/
Bandit127
« Reply #35 on: 15 March 2008, 07:25:55 »
When you're done programming your EEPROM, try it in your GPS. That many 5cm antenna all in the same place should boost your reception a treat  :)
« Reply #36 on: 15 March 2008, 08:53:27 »
I have a proper programmer for 27 series (though have to boot off a DOS disk to use), though not sure it can do 32kB chips....
Pages: 1 2 [3]  All   Go Up
