Author Topic: fuses  (Read 2324 times)
Fazeel
  • Bahrain
    • Opel Omega 3.2 V6 2002
fuses
« on: 24 November 2011, 20:53:38 »
I have a few fuses missing from the fuse box but everything seems to be working perfectly. Do I need to put in fuses from the missing spaces or  should I just leave it as it is since all is going fine ?
Re: fuses
« Reply #1 on: 24 November 2011, 21:06:42 »
probably 'spare' spaces for options not fitted to your car or for your country. One space is for the feed for a caravan 12 volt supply (27?)
If it's not broke ......... don't fix it  :y :y :y
Fazeel
  • Bahrain
Re: fuses
« Reply #2 on: 24 November 2011, 21:10:47 »
but do you guys recommend I put in all the missing ones ?
I mean, mine is a full option Omega after all isn't it ?  ???
Re: fuses
« Reply #3 on: 24 November 2011, 21:14:35 »
Have you looked inside the 'spare' fuse spaces? It's a good bet that there's either no contacts in there or just one at the very best. Mine's an Elite ie fully spec'd & not all spaces are used. As said, some might be for things like daytime driving lights in Sweden etc
Fazeel
  • Bahrain
Re: fuses
« Reply #4 on: 24 November 2011, 21:20:05 »
awh okay, I'll check for that  :y
