Author Topic: cam cover seals parts list price  (Read 4687 times)
marrus69
  • bracknell
    • 52 mv6 3.2
« on: 25 November 2011, 13:40:15 »
eden vauxhall
all parts inc vat and 1 lambda sensor for bank 2 sensor 1 at £110
£315 65
  • Online Online
Re: cam cover seals parts list price
« Reply #1 on: 25 November 2011, 13:49:49 »
on TC, camcover bits for V6 come in at under £80  :)
« Reply #2 on: 25 November 2011, 14:57:53 »
eden vauxhall
£315 65
As Tunnie says, so phone andyc at Drive Bury St Edmonds  ;) ;) ;) Andy will just bag them all up & send them out to you.  :y :y
  • Online Online
« Reply #3 on: 25 November 2011, 15:54:34 »
Yup, also safe in the knowledge you have all the little o-rings and correct sealant.
I also understand AndyC gives a slighty better price than TC to OOF  :y
Highly recommended  :y
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #4 on: 25 November 2011, 16:31:27 »
Just bought  gaskets and O rings for a 3 litre on TC,came to £84.84 in total but they gave me two bags of ten O rings.
just looked at the invoice,they only booked 16 O rings.
other rides
« Reply #5 on: 25 November 2011, 16:46:50 »
About £77 including the 16 0 rings with the trade card ;)
marrus69
  • bracknell
    • 52 mv6 3.2
« Reply #6 on: 25 November 2011, 18:51:50 »
whats tc,how can thier be such a diffarance
« Reply #7 on: 25 November 2011, 19:00:06 »
Trade club.
https://www.tradeclub.com/
To be eligible you need to join Autobahnstormers - £20 per annum.You will more than get that back the first time you buy 3 x 5litres of oil and get a fourth free,for around £45 inc. VAT. :y
http://www.autobahnstormers.org/
marrus69
  • bracknell
    • 52 mv6 3.2
« Reply #8 on: 25 November 2011, 21:11:23 »
you do no this is the parts for a v6 3.2.o to 60 in 7.4 seconds
« Reply #9 on: 25 November 2011, 21:13:04 »
Yep, they do :y
  • Online Online
« Reply #10 on: 25 November 2011, 22:46:29 »
All V6 cam cover gaskets are the same :)
« Reply #11 on: 25 November 2011, 23:00:20 »
They not. Those with a coil pack ie 2.6 & 3.2 gaskets consist of the two halves joined together while the 2.5 & 3.0 use two completely separate gaskets for each side. But that's not to say that the 4 gaskets can't be fitted to a 2.6/3.2
(I have a new 2.6/3.2 rocker cover in the garage I can photo if you like  ;) - or I would if my camera hadn't died))
marrus69
  • bracknell
    • 52 mv6 3.2
« Reply #12 on: 26 November 2011, 01:08:57 »
i have no idear the parts list says to separate ones.i will not be fitting these parts and have no idear what to do,a member on here will do it for me.i have got the lambda sensor
« Reply #13 on: 26 November 2011, 12:04:53 »
Not entirely correct, Mr B ;)
Most V6, including most 2.6/3.2 use the same 2 gaskets per bank setup.  The very last of the 2.6/3.2 use the 1 piece gasket.
My 03 3.2 uses the 'standard' 2 piece setup ;)
    • 530D M Sport, 330i Coupe
« Reply #14 on: 26 November 2011, 12:08:06 »
The join was put in place to stop water ingress. Was discovered as an issue at the engine plant so a bead of sealant was bridged between the two gaskets originally.
Page created in 0.038 seconds with 20 queries.
