Author Topic: cam cover seals parts list price  (Read 4685 times)
Re: cam cover seals parts list price
« Reply #15 on: 26 November 2011, 12:14:25 »
you do no this is the parts for a v6 3.2.o to 60 in 7.4 seconds
All V6 cam cover gaskets are the same :)
They not. Those with a coil pack ie 2.6 & 3.2 gaskets consist of the two halves joined together while the 2.5 & 3.0 use two completely separate gaskets for each side. But that's not to say that the 4 gaskets can't be fitted to a 2.6/3.2
(I have a new 2.6/3.2 rocker cover in the garage I can photo if you like  ;) - or I would if my camera hadn't died))
Not entirely correct, Mr B ;)
Most V6, including most 2.6/3.2 use the same 2 gaskets per bank setup.  The very last of the 2.6/3.2 use the 1 piece gasket.
My 03 3.2 uses the 'standard' 2 piece setup ;)
The join was put in place to stop water ingress. Was discovered as an issue at the engine plant so a bead of sealant was bridged between the two gaskets originally.
Looking at the breakpoint, I doubt any car left the factory with the modified cam cover ;)
    • 530D M Sport, 330i Coupe
« Reply #16 on: 26 November 2011, 12:29:13 »
I don't think any Omega did, Saturn maybe.
« Reply #17 on: 26 November 2011, 12:37:00 »
Late 3.2 Vectras maybe?
Or those that have had replacement engines...
