Author Topic: Need a Rover V8 expert  (Read 9121 times)
Re: Need a Rover V8 expert
« Reply #15 on: 28 November 2011, 11:26:41 »
Is the throttle pot set up correctly?
Also, the MAF on these can often also be adjusted (check to see what type is fitted)
These base settings are essential to correct operation on these units.
hoody
  • Scotland
« Reply #16 on: 28 November 2011, 12:40:32 »
check the wiring to the the ignition amplifier module,had to relace this module on the one i had a few years ago(took forever to get it to start).
Simon72
  • Wolverhampton
« Reply #17 on: 28 November 2011, 13:14:39 »
Don't think have one of those. It's a standard dissy and coil.
Not seen an amplifier around the engine bay at all.
« Reply #18 on: 28 November 2011, 13:23:39 »
Later setups had the amp mounted onto the side of the dizzy below the vac advance unit (Lucas 35DLM8 from memory).
Also, check TDC using the old screwdriver method as I have seen a few crank pulley markings which are MILES off.
hoody
  • Scotland
« Reply #19 on: 28 November 2011, 14:59:37 »
What Mark said :y
