Pages: 1 [2] 3  All   Go Down
Author Topic: Management light...  (Read 5359 times)
Re: Management light...
« Reply #15 on: 30 November 2011, 14:22:41 »
im confused... lol
Was the replacement sensor genuine GM?
omega2012
  • Kettering, Northampton
  • Web Designer / Web Host
    • 1999 2.0 16v CDX
    • Business-HostingUK
« Reply #16 on: 30 November 2011, 14:26:44 »
doesnt state it on the invoice i have for it, i have contacted the company who supplied the sensor and they have confirmed the invoice i have is a real one.
should it really matter its only been one year... a home made one could last longer than that haha!
« Reply #17 on: 30 November 2011, 14:28:16 »
So they sent you a real invoice?  ;D
Yes, it matters. Pattern sensors have been known fail within weeks  ;)
omega2012
    • 1999 2.0 16v CDX
« Reply #18 on: 30 November 2011, 14:31:17 »
ok so if it is the crankshaft sensor, you think this would explain why it cuts out when the engine managment light comes on? but the runs fine with it on....
i think it would explain the poor starting when the engine managment light is on....
« Reply #19 on: 30 November 2011, 14:36:47 »
Cutting out + that code suggests crank sensor.
Will also explain why it won't start for ages, then blast into life.
2.0, actually from memory will run with a crank sensor disconnected. Is 335 your only code?
omega2012
    • 1999 2.0 16v CDX
« Reply #20 on: 30 November 2011, 15:06:25 »
its the only code coming back with engine off... havent tried with engine on.. should i try?
where is the crankshaft sensor on this engine? il try and dis connect see what happens..
omega2012
    • 1999 2.0 16v CDX
« Reply #21 on: 30 November 2011, 15:17:18 »
matched up the invoice numbers...
omega2012
    • 1999 2.0 16v CDX
« Reply #22 on: 30 November 2011, 16:53:00 »
UPDATE - just took camshaft sensor off took her for a spin... at first drove sweet as a nut ... engine mangement light was on from the start of my trip... got about 5-7miles and he just died... no splutter or anything like that just died... pulled over plugged sensor back in and she started up like normal (rough)
any ideas?
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #23 on: 30 November 2011, 17:01:47 »
camshaft sensor
not cam sensor crank sensor that is what code p0335 is pointing at  :y
martin42
« Reply #24 on: 30 November 2011, 17:03:45 »
omega2012 im also in kettering if your stuck at anypoint   :y
fiend61
  • york
  • each to their own
« Reply #25 on: 30 November 2011, 17:07:06 »
p0340 is camshaft sensor if you had this code aswell as the p0335 i would suggest changing cam sensor ignoring the cranksensor unless it re-occured but seeing as you only have code p0335 it is deffo the crank sensor  :y
fiend61
  • york
  • each to their own
« Reply #26 on: 30 November 2011, 17:11:37 »
Actually ignore me I was thinking of code 31
i will tunnie  ;D ;D ;D ;D
fiend61
  • york
  • each to their own
« Reply #27 on: 30 November 2011, 17:15:59 »
umm how does that work then   :o  doesnt crank sensor supply the signal for spark and fuel pump  :-\  so therefore without crank sensor connected how would it start (baffled)
but something i dont know so asking  :y
« Reply #28 on: 30 November 2011, 17:16:59 »
No idea, read it on here several times.  :-\
fiend61
  • york
  • each to their own
« Reply #29 on: 30 November 2011, 17:18:22 »
oh ok  ;D ;D ;D
an expert will be along to explain hopefully  :y
Pages: 1 [2] 3  All   Go Up
Page created in 0.024 seconds with 16 queries.
