Author Topic: ncdc 2013  (Read 8942 times)
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
ncdc 2013
« on: 01 December 2011, 06:52:25 »
hi all
right i have a ncdc 2013 what i would like to know is if the ncdc2015 telematics unit can be retrofitted to the 2013, i have the chance to get the telematic unit cheap and miss the phone function with the 2013
if this is possible what loom parts would i need to connect to the hu
thanks
ps- i take it that the telematic unit doesnt have to go through the pairing/depairing route ?
Re: ncdc 2013
« Reply #1 on: 01 December 2011, 09:37:40 »
IIRC it does, but I'm not an expert. :-\
fiend61
  • york
  • each to their own
Re: ncdc 2013
« Reply #2 on: 01 December 2011, 09:40:03 »
no nor me but like to dabble  ;) ;D
davednd will hopefully put me right (one way or the other)  ;D
Re: ncdc 2013
« Reply #3 on: 01 December 2011, 09:43:31 »
I reckon TB is probably the best person to answer this.. but I'm sure I recall him writing that the only difference between the 2013 and 2015 was software config and the label on the two front buttons.
Re: ncdc 2013
« Reply #4 on: 01 December 2011, 09:45:56 »
Have a feeling the NCDC2013 will be need to told it has telematics, as mine even though it does not have it, thinks it does  ???
I'm going to vote no, it does not need de-pairing but does need to be enabled on the new H/U  :y
fiend61
  • york
  • each to their own
Re: ncdc 2013
« Reply #5 on: 01 December 2011, 09:53:57 »
thats what i am hoping tunnie  :y  even if it needs a session to tell the h/u that the telematics are there or whether it recognises it when plugged in, so im assuming you have a 2013 which has been configured /or has had a telematics attatched previously and it still thinks its there?
depending on outcomes then i might be able to sell you the telematic unit or have a swap session with your units for mine  ;)
« Last Edit: 01 December 2011, 09:56:04 by fiend61 »
Re: ncdc 2013
« Reply #6 on: 01 December 2011, 09:55:46 »
Have considered Telematics, but I think if I did get anything it would be a bluetooth kit  :-\
fiend61
  • york
  • each to their own
Re: ncdc 2013
« Reply #7 on: 01 December 2011, 09:58:31 »
thought about bluetooth kits aswell, but really miss the phone capability that i have in the cdx with the ccrt700  :(
Re: ncdc 2013
« Reply #8 on: 01 December 2011, 10:07:05 »
Problem for me is telematics would be a separate number, having to divert calls, then pay for possible divert, remembering to cancel it when not in the car and so on.
This looks interesting:
http://www.bluetoothcarkitdirect.co.uk/Bluetooth_Kits/Bury_THB/Bury_THB_CC-9060_Bluetooth_Car_Kit
Says it uses a standard ISO lead, but music functions would be pointless I think as its Mono input on the NCDC  :(
fiend61
  • york
  • each to their own
Re: ncdc 2013
« Reply #9 on: 01 December 2011, 10:16:23 »
yup agree sounds ok, but really dont like things stuck to my dashboard etc  ::) that is why i am looking at the standard setup
hmm just thought will have to check i have the microphone in light i take it that this system still uses that??
Jack-V6
  • Netherland
    • omega Y2.5DTI 2003
    • opel omega portal
Re: ncdc 2013
« Reply #10 on: 01 December 2011, 12:55:14 »
You can tel de ncdc with the tech 2 that he has a telematica.
Bluethoot is terrible with bose. Like sombody screems to you even on low sound level.
A had a parrot ck 3100 in my omega sounds like hell. have a dual simcard from my provider. only problem is that it works only with 900mhz.
Gr Jack
Re: ncdc 2013
« Reply #11 on: 01 December 2011, 19:03:04 »
NCDC2103 can run a telematics, although about 5 buttons have the wrong legend on them once configured.
It requires the telematics to be in Delivery Mode (if its not in Delivery Mode, and you don't know the pairing code, its an expensive doorstop).  Obviously requires a chat with a Tech2.  NCDC2013 security code required as well...
fiend61
  • york
  • each to their own
Re: ncdc 2013
« Reply #12 on: 01 December 2011, 19:13:25 »
thanks TB how would i know if telematic unit is in delivery mode, and would the person im getting it off know the pairing code ??
and the ncdc code is the car code isnt it ?
right that didnt make any sense at all  :-[
what i meant to say is that he person i am getting it off should have had it depaired and know the pairing code?
the ncdc 2013 is in my car and i have the original carpass which i got with h/u is that the security code?
Re: ncdc 2013
« Reply #13 on: 01 December 2011, 19:40:09 »
Only the seller can tell you if its in delevery mode (or what pairing code is if its not (although that adds extra complications)).
Yours, if factory fit, and hasn't been molested, it will be car's PIN
    • 530D M Sport, 330i Coupe
Re: ncdc 2013
« Reply #14 on: 01 December 2011, 21:37:44 »
I've got a staircase building!!!!
