Author Topic: Oil again  (Read 2825 times)
moose
  • SWINDON WILTS
Oil again
« on: 01 December 2011, 17:03:37 »
Hi again
Filled the car with about 2 litres of oil , now showing full ??
Re: Oil again
« Reply #1 on: 01 December 2011, 17:07:10 »
Give us a clue. What engine? Even 4 pots should take 5L. You removed sump plug?
moose
  • SWINDON WILTS
Re: Oil again
« Reply #2 on: 01 December 2011, 17:14:39 »
I checked oil today and it was completely empty, no issues before.
I expected to put the full 5:75 litres in but only got about 2 in there
Can't find any leaks so it's all a bit strange.
moose
  • SWINDON WILTS
Re: Oil again
« Reply #3 on: 01 December 2011, 17:16:47 »
Sorry 2:6 v6
Re: Oil again
« Reply #4 on: 01 December 2011, 17:20:43 »
The bottom of the dip stick doesn't mean there's no oil in the engine! I'm guessing you still had 3 litres+ still in the suimp.
If it had really run out you would have lost oil pressure and the engine would be in a very poor state of repair by now.
I would look into why the low oil warning didn't happen, though.
moose
  • SWINDON WILTS
Re: Oil again
« Reply #5 on: 01 December 2011, 17:53:53 »
Thanks, can anyone tell me where the oil pressure sensor is on a V6 ?
Re: Oil again
« Reply #6 on: 01 December 2011, 17:58:11 »
You want the oil level sensor which is in the sump. From the bottom of the dip stick to top is 1L
So you did not drain sump & refilling? Quite possible you have considerably overfilled!!!
Re: Oil again
« Reply #7 on: 01 December 2011, 18:14:50 »
Possible stem seals, and you should have had an oil check pop up on the dash.
Re: Oil again
« Reply #8 on: 01 December 2011, 19:46:43 »
Unless GLS ;)
moose
  • SWINDON WILTS
Re: Oil again
« Reply #9 on: 01 December 2011, 22:52:12 »
Hi all,
Pu 1 and half litres in and it's topped up to max
Running ok cant see any leeks from top but want
To check the oil filter isn't loose as there are signs
Of oil on left side of engine and sump , where the
Hell is the oil filter,,,,,thanks in advance guys.
Re: Oil again
« Reply #10 on: 01 December 2011, 23:09:02 »
.... where the hell is the oil filter,,,,,thanks in advance guys.
Top of the engine, passenger side.
re your original question. You need to start again, I don't think anyone has a clue whether you put a couple of litres into your engine after an oil change or just routine. As Kevin says, if it was empty, then a couple of litres would've been too late & your engine would be seized. When did you last check the level & how many miles have you driven since? You might just have a severe leak.  :-\ :-\ :-\
moose
  • SWINDON WILTS
Re: Oil again
« Reply #11 on: 01 December 2011, 23:42:00 »
hi,
i checked the oil today and it was bone dry,put in 1 and half litres of oil and is now showing full on dipstick.
Never had any probs with oil before or needed to top up.checked oil about 3-4 weeks ago and it was fine.
no puddles on drive , just cant understand what happened here as had the car 6 yrs and never had to put oil in.
if the filter is top passenger side i will check tomorrow.
cheers
marcus.
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
Re: Oil again
« Reply #12 on: 01 December 2011, 23:46:58 »
opppps  ::)   wonders how many miles done in 6 years  ::)
what is the car you say v6 but what spec???
moose
  • SWINDON WILTS
Re: Oil again
« Reply #13 on: 01 December 2011, 23:55:53 »
its a 2006 MV6 only done 75k with 40k on clock when bought,regular main stealer serviced every year.
fiend61
  • york
  • each to their own
Re: Oil again
« Reply #14 on: 02 December 2011, 00:00:33 »
ahhhh ok  :y
then to suddenly lose 1 1/2 to 2 litres of oil is serious , did you check filter? also surely on a mv6 you should get  low oil warning  :-\ :-\
