Author Topic: OK,Ive Cocked Up Somewhere, Any Ideas  (Read 2312 times)
Tankie1rtr
  • York
« on: 01 December 2011, 21:30:13 »
 >:( Hi Guys.  Miggy. 2.2 Diesel
Can anybody give me any ideas, I wanted to put a hand prime (Rubber Ball Type) between my Fuel Filter and my Injector Pump. I have cut the Out Pipe (That goes from the Fuel Filter to the Injector Pump) and fitted the primer bulb, with direction of flow to the Pump, I have used a small jubilee clip over both ends fuel pipe and made sure they are tight. I have also put in a new fuel filter. I filled the filter bowl with Diesel Magic and re-assembled it. I had to use Cold Start to fire her up, and I left her runnning on a slightly fast tickover for 10 minutes, I let her stand idle for about 2 hrs then fired her up took her to the garage to have an Oil Flush and new Oil with Filter. She drove home fine. I left her for about 3 hours and went out to put her on he drive, she just turned over and wouldnt fire, I had to use Cold Start down the Air Vent to fire her up again, once running she is like a dream, I took her for a blast along the Motorway and she breezed along at 90mph, home and she ticked over fine. I left her for two hours and went out to put her on the drive, and she wouldnt start again. has anybody any ideas what I could try, or look for. I have had her for 3.5yrs and never had any trouble until today, it must be something I have done or cocked up in some way..
Chaeers.
Tankie1rtr
    • 530D M Sport, 330i Coupe
Re: OK,Ive Cocked Up Somewhere, Any Ideas
« Reply #1 on: 01 December 2011, 21:40:58 »
Leak off pipes?
Try parking with the nose facing downhill and see if that improves matters and therefore proves the above!
Tankie1rtr
  • York
« Reply #2 on: 01 December 2011, 22:04:50 »
Also. I do not know if it will have any bearing but, when she was ticking over at about 600, I gentley press the accelerator and she seem to hesitate for a brief second then jumps up from 600 on the rev counter then climbs normaly, I let the gas off, then apply gas again and it does exactly the same thing, seems to stick for a micro second then suddenly raise in revs..  (If that makes Sense)
Cheers
tankie1rtr
« Reply #3 on: 01 December 2011, 22:19:04 »
Try 'repairing' the fuel pipe you've split into with a section of plastic tubing & a couple of Jubilee clips and see if that fixes your problem. Not sure exactly what your pump looks like or exactly where you've fitted it.  :-\
robmac
« Reply #4 on: 01 December 2011, 22:22:18 »
would the hand prime pump be "sided" ?...maybe its causing a restriction??
mrgreen
  • Salzburg/austria
    • 2000 2.2 petrol estate
« Reply #5 on: 01 December 2011, 23:09:08 »
i'm geussing the pressure aint right, but i know nothing!, and by spraying a bit of etha down there with a lower combustion point it's starting and then all evens out, food for thought?
Warning: Dates in Calendar are closer than they appear.
« Reply #6 on: 01 December 2011, 23:10:53 »
Sounds feasible  :-\ :-\
tidla
  • solihull
« Reply #7 on: 01 December 2011, 23:32:40 »
foundf this the hard way doing a veg conversion. the plastic pipes get crushed using standard jubilee clips which in turn let in air/drain back. best to use plastic pipe inserts made of brass(available from comercial parts suppliers) and a fuel line clip of sutable diameter.
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #8 on: 01 December 2011, 23:43:44 »
Sounds feasible, though I'd shy away from using that aero-start stuff.
