Author Topic: Corsa D 1.3CDTi issue  (Read 9745 times)
    • 530D M Sport, 330i Coupe
« on: 03 December 2011, 18:33:59 »
Hoping someone may be able to help, I haven't read the codes yet (though no engine management light on) but my fathers Corsa occasionally won't rev past 4K, usually when under load (accelerating up a hill), can be hot or cold.
Just wondered if this was a common problem?
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Corsa D 1.3CDTi issue
« Reply #1 on: 03 December 2011, 18:38:19 »
I've had one of those with a stuck wastegate on the turbo,gives a turbo overboost code and chucks it in limp mode.
other rides
« Reply #2 on: 03 December 2011, 19:57:57 »
No waste gate on these as they are a variablke geo turbo.
Read the codes as it could be a few things, question has to be, why the hell is it being revved to 4K!
« Reply #3 on: 03 December 2011, 20:41:49 »
Will read codes in the morning  :y
Unfortunately the road from my sisters requires you to go up a steep hill, in order to get past the slow moving lorries you need to use all of that tiny turbo! If you change up before hitting 4K you'll end up in a rev range below when the turbo cuts in and just end up slowing down.
Regardless the engine should be able to rev to the limiter, if you put your foot flat to the floor when it's in neutral it should be able to rev up to the red line.
PS. The paint stripper has done a good job!  8)
henryd
  • west cornwall
« Reply #4 on: 03 December 2011, 22:54:45 »
looking up from underneath between the block and the turbo there a rod which goes to a pivot,is that to alter the vanes?,that's the bit that was jammed up on the one I saw,once free'd off light stayed out.
other rides
« Reply #5 on: 06 December 2011, 19:28:52 »
Well the pedal test gives 5 flashes followed immediately by a single flash then a pause, one flash, pause, two flashes, pause, three flashes.
Not sure how to read that, guessing 6123 but doesn't sound a valid DTC.
Unfortunately I don't have a CAN capable code reader at the moment.
« Reply #6 on: 06 December 2011, 19:48:55 »
Yep.
the alarming man
  • medway kent
    • disco V8
« Reply #7 on: 06 December 2011, 20:14:14 »
you can't with the new focus,pug 308 or vw transporter..if you are parked up it wont rev past 2500 rpm :y
« Last Edit: 06 December 2011, 20:16:56 by the alarming man »
Ian_D
  • York
« Reply #8 on: 07 December 2011, 04:54:02 »
I always thought that diesels were taken to the limiter during the MOT? Hows this work if they are limited at 2500rpm???
[size=12]
Martin P
  • Colchester Essex
  • VX Trade card holder
    • 2.2 Cdx Est
« Reply #9 on: 07 December 2011, 08:42:17 »
Needs to be in gear clutch down and handbrake off to get it past 2.5k revs from memory. My old rover 600 TD was the same rev's cut to under 2.5k unless brakes off an in gear
