Author Topic: heater not working  (Read 4546 times)
nelson
  • sleaford
    • 2002 2.6 Estate
heater not working
« on: 04 December 2011, 12:20:19 »
hi
I'm new on this site I have owned my Omega from new and do most of the repair on it myself.
My climate control has started running cold.
Once the engine has warmed up the fan does not appear to work unless I turn it to either high or low. Where ever it is it does not get hot.
When turning the auto switch on or off you can hear a noise I assume it a selenod opening & closing
If the demiser is turn on the fan works but again no hot air.
Any help would be much appreciated
Thanks
Fred
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: heater not working
« Reply #1 on: 04 December 2011, 12:31:25 »
You could try synchronising first, switch ignition on, press and hold Auto and Off at the same time, and hold for about 20 seconds.
I like red cars
nelson
  • sleaford
    • 2002 2.6 Estate
« Reply #2 on: 04 December 2011, 15:27:48 »
Thanks
but that did not work
  • Auckland
    • Mazda MPV
« Reply #3 on: 04 December 2011, 16:13:56 »
Are you saying that your climate fan is either off or full speed but nothing in between?
IIRC this is usually a sign of the fan speed controller failing.
The fan speed controller looks a bit like a hedgehog and is situated in the air duct behind the glove box. If the drain holes in the scuttle get blocked water finds its way into the ventilation duct and can cause its demise (as well as filling the passenger footwell with water).
Have a read of this guide Scuttle Drain Cleaning
« Last Edit: 04 December 2011, 16:17:59 by Andy H »
nelson
  • sleaford
    • 2002 2.6 Estate
« Reply #4 on: 04 December 2011, 16:18:18 »
No I believe the fan is okay When I use the dimister I can ajust the fan speed okay
Will have a look to see if the scuttle drain is blocked
Thanks
  • Auckland
    • Mazda MPV
« Reply #5 on: 04 December 2011, 19:36:16 »
OK next question
Does the outside temperature display give a sensible reading? or does it read 'F'
nelson
  • sleaford
    • 2002 2.6 Estate
« Reply #6 on: 04 December 2011, 22:06:50 »
Yes the outside temperature works fine
nelson
  • sleaford
    • 2002 2.6 Estate
« Reply #7 on: 05 December 2011, 14:13:33 »
Think I have worked it out.
It's either the heater matrix blocked or the valve that lets the hot water flow into the matrix thats not working.
I realised  this morning (drove 26miles in the cold) that the blower does not start working until the heater has got warm.
When I stopped I checked the heater pipes and they were cold. I'am going to change the valve first as I think it is more likely that as the heater stopped working suddenly. I think if it was the matrix blocked it would have gradualy got cooler. Famous last words!!
Rich-K
  • West Yorkshire
« Reply #8 on: 06 December 2011, 13:07:58 »
It may sound a silly question, but is the engine coolant level topped up? If no water in radiator then heater wont work.
« Reply #9 on: 06 December 2011, 13:10:03 »
is the vacuum connected up? Can never remember which way the HBV works  ... no vacuum - no heat or is the the other way round ??? ??? ???
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #10 on: 06 December 2011, 13:15:12 »
vacuum applied no water to heater     no vacuum water runs through the heater  :y
« Reply #11 on: 06 December 2011, 13:22:50 »
The heater Bypass Valve has vacuum to the top of it & moves the valve via a diaphragm  :y
fiend61
  • york
  • each to their own
« Reply #12 on: 06 December 2011, 13:25:42 »
yup i know andy  ;D
no vacuum means water will run through the heater so op wants to remove vacuum pipe and see whether that makes any difference  :y
« Reply #13 on: 06 December 2011, 13:41:00 »
yup i know andy  ;D
Sorry! I understand what you put now!  :y
OP could try sucking on the pipe to the HBV too  ;)
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #14 on: 06 December 2011, 21:42:58 »
What would this achieve / correct?
