WTD rear shocker
Started by tango, 09 December 2011, 15:52:46
tango
wanted
driver side rear shocker for 2.6 elite
with self levelling
are they cheap new or is used best option
twiglet
IIRC they are only available from Vxl new, and are £160ish  :o
You may be lucky and find one S/H, but you can never know how long it will last.  :-\
Best to replace in pairs if at all possible,although realistically,many people are on a tight budget these days.
tango
thanks for the replies
"tight budget" definitly
but has any body got any decent second hand or can i put standard shocks in
You couldpull he fuse from the self levelling and use standard shocks.Problem then may be that the S/L springs may be too soft,so you need a pair of non S/L springs also.
Quote from: Albs on 09 December 2011, 19:36:05
You could pull the fuse from the self levelling and use standard shocks.Problem then may be that the S/L springs may be too soft,so you need a pair of non S/L springs also.
bored bigyin54
that was done with mine and it was to soft so put self raising back on
bored bigyin54
i think i had the last second hand shocks on here
twiglet
I can probably sort you out with a set of nearly new non-s/l shocks and matched springs if you need them mate.  :y
tango
thanks for the replies guys
i think ill stick to the self leveling setup
twiglet how much do you want
twiglet
#10
Tango, if you want to stick to the S/L setup, then I can't help you mate.  All the sets I have here are non-S/L.   :(
