Author Topic: pulley  (Read 2238 times)
flyer 0712
pulley
« on: 09 December 2011, 16:29:19 »
hi my to all.....on my omega 2.2  the crankshaft main belt pullet appears to have a small rubber insert going around the the inside diameter on the front...to what purpose is this for....i ask because mine appears to be trying to come out from between the joints    cheers...
Matchless
  • Nottingham
    • A white van
Re: pulley
« Reply #1 on: 09 December 2011, 16:33:46 »
The pulley is actually described as a torque damper in the parts list.
Im not sure wether it is intended to smooth the torque delivery to things driven off the aux belt or wether it acts as a vibration damper to the crankshaft.
The rubber bonding can fail and the outer rim of the pulley comes off so replace it if it is badly deteriorating.
flyer 0712
Re: pulley
« Reply #2 on: 09 December 2011, 16:43:38 »
thank you...my main reason for asking is i have said on here recently i have a bad vibration on tick over in drive with foot on brake and the car shakes somewhat...replaced engine mounting....other one ok...gearbox mounting appears ok...exhaust mountings ok..so i was looking under the bonnet to day could not find anything wrong ..put my hand on top of engine and it does vibrate a bit...nothing loose or brackets broken then i spied the crank shaft pulley with this rubber in it just appears to be trying to escape just a bit.....so i may as well change that and see...thanks ray...
innarightestate
Re: pulley
« Reply #3 on: 11 December 2011, 12:14:31 »
hi my pulley disintergrated recently.new one fitted plus belt the old one broke off as istarted the engine luckerly i was nearlly home .lost p/sterring and charging.which made it a bit of a bas?to get home.bourt a pulley and belt of ebay total cost £55 but had to get it fiited by a freinds gararge as it was a pain to undo crankshaft bolt emensly tight .allgood now.pulley fiited is a solid one whith out rubber centre which is better no more problems hopefully.cheers :)
Page created in 0.025 seconds with 20 queries.
