Author Topic: No Dash Board ignition Lights !  (Read 6070 times)
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: No Dash Board ignition Lights !
« Reply #15 on: 13 December 2011, 17:59:30 »
Glad you got it sorted
Radio & Decoding Technician
www.dndservices.co.uk
E30 Turbo
  • Norway
    • Omega 3.0Mv6
« Reply #16 on: 19 December 2011, 13:32:38 »
I have the same problem on my 1995 3.0mv6 now, and I've tried to remove the cluster and put it back today, with no luck! :( The speedo needle is stuck on 40km/t (speed when this happend) and the powerwindows doesent work, neither does the "s" button and the winterprogram on the gearbox, and sunroof, automatic driving lights, radio.
Seems like the power supply to these things are missing, but no broken fuses. The heater does work in all levels, and the car runs just like before..
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
« Reply #17 on: 19 December 2011, 20:26:28 »
would check fuse with meter, if ok check for volts at fuse, if no volts remove fuse box and check the back of the fuse box, if fuse is ok and there is power check the fuse clip it may be lose or correded up. if they all fine check earth wires under the battery bay to the left. also the eath wires in fuse box area, will need to remove and look up the hole to see them.
« Last Edit: 19 December 2011, 20:28:09 by freecall666 »
Solar charger fitted.
If not Broke dont fix it..
E30 Turbo
  • Norway
    • Omega 3.0Mv6
« Reply #18 on: 20 December 2011, 22:45:50 »
Tnx! I give it a try tomorrow  :)
