Author Topic: elite suspension  (Read 4479 times)
tango
  • brum
elite suspension
« on: 11 December 2011, 20:44:03 »
hi all
just wondering if someone of you can provide some info on my elites self leveling suspension
basicly i want to know how it is set to work
for example
when i put something heavy in the boot , is it suppose to raise the height from the rear to match the front,
and if yes then once raised does it sit there and for how long
or does it reset on when ignition turned off and raise again when igniton turned on.
also regarding the front, are the front self leveling or are they fixed and used as a guide for the rear.
Omega32E
  • Leicestershire
    • Omega 3.2 E
Re: elite suspension
« Reply #1 on: 11 December 2011, 21:28:36 »
Will try and explain this and if there are errors I am sure somebody will be along to correct them.
The shocks are pumped with air that is provided by a compressor that is mounted under the offside front wing, the level is controlled via a valve mounted on the offside on the rear axle, from what i understand the compressor only runs when the ignition is first switched on. The compressor also has a relief valve which releases air till the vehicle has attained its correct pressure/height for the given load on the car. So when you first start the car the compressor runs puts air into the rear shocks controlled via the valve and released via the compressor as needed, the compressor does not run again until the vehicle is stopped and restarted.
Think thats how it works :y
« Reply #2 on: 12 December 2011, 08:40:49 »
Only rear has self levelling. This is active any time the ignition is on.
A compressor mounted behind drivers headlight, or mounted under the car about halfway down (depending on engine) pumps up air bladders in the rear shocks, or relieves pressure in air bladders to lower.  This is monitored continously when the ignition is on.  It not a fast acting system, so it can take a minute or so for it to attain the correct height.
Many Elites have had it disabled due to peopl'e fascination with pattern shocks ;)
tango
  • brum
« Reply #3 on: 12 December 2011, 09:44:46 »
Ok so if the front is fixed
And assuming all is working fine
Will I be correct in saying that
If I put some lowering springs in the front
The rear will adjust itself to the required level
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #4 on: 12 December 2011, 09:52:55 »
No, the rear will stay at the same height as before.
other rides
« Reply #5 on: 12 December 2011, 10:03:21 »
and you will have a very unstable vehicle.
By playing with just the front suspension, purely for "looks" at a guess, you will have a totally unbalanced and IMHO, dangerous, setup.
« Reply #6 on: 12 December 2011, 10:20:34 »
Kinda depends.  My MV6 is like that, to make it more 'pointy' on cornering, and to overcome that Omega understeer on sweepers.
The MV6 does have factory sports suspension at the rear, though, albeit now on Bilstein B4 shocks.
Although I certainly wouldn't be lowering the front and using Elite rear suspension, that would be far to twitchy for me.
That said, I think I may try popping some Irmscher springs on the rear of the MV6, just to see how I get on, as I am reasonably happy with TBE's setup.
henryd
  • west cornwall
« Reply #7 on: 12 December 2011, 10:33:18 »
Also the auto leveling for the HID headlamps will be all to hell as well.
other rides
« Reply #8 on: 12 December 2011, 10:40:25 »
Nah, it'll cope (unless one end is on the deck, and other end is jacked up like a monster truck)
henryd
  • west cornwall
« Reply #9 on: 12 December 2011, 11:04:51 »
Really ?,I would have thought with the front 30 mm lower and the back where it should be the lights would be pointing down lower.
other rides
tango
  • brum
« Reply #10 on: 12 December 2011, 12:16:56 »
thanks for replies everyone
but still a bit baffled as getting mix responses
surely if the elites suspension is designed to  SELF LEVEL
and it it uses the front as a guide
then i dont see why it wont lower the rear itself to compensate
« Reply #11 on: 12 December 2011, 12:28:16 »
It doesn't use the front as a guide. In fact, it doesn't even measure the level at the front. It just jacks the rear up or lets it down as required to set a constant ride height at the rear. Lower the front and it won't change the level at the rear at all, the car will just end up raked towards the front, which may upset its' handling.
tango
  • brum
« Reply #12 on: 12 December 2011, 12:37:31 »
ok that explais it better
so how would i go about lowering it if i wanted
« Reply #13 on: 12 December 2011, 18:34:52 »
If you want it lowered, it has to be stiffer. That means new shocks and springs all around, and loosing the self levelling.
« Reply #14 on: 12 December 2011, 18:35:57 »
It'll cope ;)
