Author Topic: multi-piston calipers - master cylinder upgrades....  (Read 929 times)
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« on: 12 December 2011, 18:12:14 »
Hello,
I know its a bit of an odd question,
Does anybody know of something GM or otherwise that has a larger capacity master cylinder for use on an omega with 4 pot front and 2 pot rear calipers as alot of the GM stuff uses single pot double acting calipers- even on the corvettes, obviously i'd prefer if it was a straight swap lol otherwise i would just get an evo 5 with front brembos master cylinder
thanks in advance
Alex
V8!!!!
2woody
  • Northumberland
Re: multi-piston calipers - master cylinder upgrades....
« Reply #1 on: 12 December 2011, 18:17:27 »
probably wouldn't mess with the master cylinder unless you really know what you're doing - it's quite carefully matched to the ABS.
4-pots are no great advantage for any application short of an endurance racer - their main benefit is keeping the fluid cooler for longer.
brake mods must be seen in a "whole-vehicle" way, with the front capability very carefully matched to the rear capability.
I had a devil of a job getting something to match the bigger fronts I put on the evo.
