Author Topic: How do I replace front black plastic grill that holds fog lights?  (Read 1771 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Hi guys,
As above. I've looked in the maintenance guides and can't find one. I've also looked at the plastic grill on my car. It appears that this is in sections as opposed to one whole grill. that would be handy as it appears only two of the centre ''sections'' are bent.
so do they simply unclip so you can replace?
thanks in advance. i'l then put an ad in the wanted section for the part.
also will post a how to guide if would help anyone else?
cheers.
RIP Paul Lovejoy
Re: How do I replace front black plastic grill that holds fog lights?
« Reply #1 on: 14 December 2011, 15:48:00 »
In a word 'YES'. :y Probably easiest with the bumper off, but then self explanitary. :y
see this for help:http://www.omegaowners.com/forum/index.php?topic=90683.0. :y
Webby the Bear
  • Northampton
« Reply #2 on: 14 December 2011, 15:52:01 »
Thanks TA.
Can you post that link again though as it says it aint valid ;)
cheers.
RIP Paul Lovejoy
« Reply #3 on: 14 December 2011, 15:56:33 »
http://www.omegaowners.com/forum/index.php?topic=90683.0  :y
Seemed to work OK from here, but here it is again :y
Webby the Bear
  • Northampton
« Reply #4 on: 14 December 2011, 16:01:11 »
Cheers mate  ;)
Do you know if the grill is in sections?
RIP Paul Lovejoy
« Reply #5 on: 14 December 2011, 16:03:30 »
Two halves and a towing flap cover IIRC. :-\ Should be obvious once you've got the bumper off. :y
Webby the Bear
  • Northampton
« Reply #6 on: 14 December 2011, 16:09:36 »
cheers sunshine  ;)
RIP Paul Lovejoy
