Author Topic: Heater/Blower/fan motor not coming on  (Read 6276 times)
Re: Heater/Blower/fan motor not coming on
« Reply #15 on: 06 January 2012, 17:49:25 »
As RobG says, only need glovebox out to change speed controller.  Bit fiddly.
  • Auckland
    • Mazda MPV
« Reply #16 on: 06 January 2012, 19:51:53 »
Probably not helpful but..
My recollection is that the top flange of the glove box is clamped behind the lower edge of the air bag module. 3 torx screws hold the lower edge of the air bag module.
I have always taken the 3 torx screws out and gently prised the lower edge of the air bag up to allow the glove box to come out.
If you already have the glove box out then I presume *someone* must have cut the top edge off the glovebox to allow it to come out..............
PS - sparks from a grinder are astonishingly effective at burning little pits in (or welding themselves to) the inside of your windscreen.
Cliffo B
  • Leeds West Yorkshire
    • 03 3.2 Elite Estate
« Reply #17 on: 06 January 2012, 22:36:46 »
Thanks Andy,Ive managed to get the glovebox off and the airbag cover as per
Jimbob's "howto"
The top edge of the air bag cover is secured by a 8"long thin bolt which acts as a hinge pin
I've checked the motor as you advised Kevin and it's OK :y
Thanks
So full speed ahead with a replacement speed controller
« Reply #18 on: 06 January 2012, 22:47:47 »
Jimbob's "howto"
Thanks
Did you manage to sort one Cliff
« Reply #19 on: 07 January 2012, 00:00:19 »
Yes. :y :)
Cliffo B
« Reply #20 on: 07 January 2012, 13:19:18 »
Thanks Rob have one on it's way :y
Just been out to Miggy for a reappraisal
Going to follow your advice and fit the speed controller with airbag in-situ
Allthough got some strong reservations/worries about previous work done with regard to the 4 No 30 airbag torx screws
What I need to know is:-
As the screws are special
They have a flanged head that forms a fixed washer with the underside of the flange toothed to bite in to the airbag metal brackets
Question is:-
Is the airbag system electronicaly sensitive to the torque setting of the 4 torx screws??
Has someone stripped the splines off 2 screws and damaged the 2 others because of system Fault Codes?
As I have released 2 screws could be I could have fault codes on power up
« Reply #21 on: 07 January 2012, 14:04:56 »
I don't believe so.
If its the ones (or identical to) the 3 that you undo to remove glovebox, I should have some here if you want to change them. If you want them, PM your address and I'll pop in post, but can't do for a few days due to manflu  :-[
Cliffo B
« Reply #22 on: 07 January 2012, 15:40:05 »
Thanks TB their not the same
I have some on order at the dealers
Just in case I finish up haveing to do a drill out job
Sorry about the Manflu
What works for me is the full course of 500ml paracetamol capsules not pills
Backed up with a generous bedtime slug of whiskey & hot water to sweat it out :y :y
Cliffo B
« Reply #23 on: 07 January 2012, 23:15:14 »
Just been searching the Forum to find out how the speed controller is fixed in
Could'nt find anything but found some pics of the S/C
Visuals of it located in the car appears as if it could be latched into it's housing
It would be nice to remove it tomorrow ready for Monday
So I'll have a go and fiddle around
Any advice/tips much appreciated :y
« Reply #24 on: 07 January 2012, 23:52:58 »
Get yourself upside down in the passenger footwell with a torch.Its just held on by two plastic clips,one attached to either side.
Similar to most electrical connectors - you press the bottom of them in towards the side of the controller to allow them to open out at the top, and then pull it out.
Cliffo B
« Reply #25 on: 08 January 2012, 12:04:20 »
Thanks Albs should be ok with that info no probs with getting upside down :y
Getting back right way up could be a differant ball game ;D
Cliffo B
« Reply #26 on: 11 January 2012, 11:28:46 »
Yip Yippee ;D It seems the Climate Control is now in Apple pie order :y
Will be setting off shortly for our weekly 130ml trip to the East Coast so can do some testing
Can endorse the fiddly job comments
And managed to make the on back in footwell access easyier
Used a piece 3" foam ::)
Heartfelt thanks to all for the usual Forum excellent info and advice :y
« Reply #27 on: 11 January 2012, 11:37:37 »
Glad your sorted Cliff. :y............will keep you informed about proceedings with Royal Fail. ;) ::)
Cliffo B
« Reply #28 on: 11 January 2012, 11:39:13 »
And not to forget Albs who sorted me out the Speed Controller :y :y
