Author Topic: early mid to newer mid... simple to change or?  (Read 2919 times)
Ahermann
  • NORWAY
    • OPEL Omega 2.0 16v cd -97
« on: 17 December 2011, 22:27:04 »
hello i have a omega 2.0 16v from 1997 that has the "early" mid computer and of course it has just half the pixels left..(lol)
i am planning to get a new one and i wonder if it is possible to mount the new type of mid instead of the old one?...
by the way..i read in a topic that mid only came in german or english..that it not true as omegas here in norway came with swedish text...
Re: early mid to newer mid... simple to change or?
« Reply #1 on: 18 December 2011, 09:20:45 »
its a case of slightly modifying the wiring and the plug at the back.
if you have a wiring diagram, should be fairly trivial
Ahermann
  • NORWAY
« Reply #2 on: 18 December 2011, 09:29:46 »
any ide where to find the diagram then? and i guess it is importent to get a plug for the new display wit some wireing attached..
there isnt anybody that has made a konverter cable? with 2 plugs in one end and the one plug in the other end?
« Reply #3 on: 18 December 2011, 09:54:06 »
never seen converter cable.  I think the individual pins can be removed from yellow and black plugs and slipped straight into the grey plug housing.
Haynes, from ebay, has the wiring diags for both
Ahermann
  • NORWAY
« Reply #4 on: 18 December 2011, 12:09:11 »
haynes books?
if that is the case i guess i would need to find a grey plug then
Ahermann
  • NORWAY
« Reply #6 on: 18 December 2011, 13:26:30 »
ahh well i wont need to buy it as i allready has it..just didnt remember to have seen the diagrams ...i will look it up.. thanks alot
« Reply #7 on: 18 December 2011, 13:37:15 »
Chapter 12, there are 2 lots of diagrams, 'Early cars' (94-97) and 'Later cars' (98-99)
So you have the wiring and pinouts for early and late MIDs :D
Ahermann
  • NORWAY
« Reply #8 on: 18 December 2011, 15:15:23 »
i also read that you might have to alter things as language and motor type and so on with computer...tech 2
would any tech2 cable work? and is there anything special programs and so on?
« Reply #9 on: 18 December 2011, 18:53:55 »
Correct, unless you get the one with correct config on.
*MUST* be the genuine Tech2 (about €4,000), not the shiity leads on ebay with a name of tech2
Ahermann
  • NORWAY
« Reply #10 on: 18 December 2011, 22:42:01 »
well i guess that my lokal opel service has such equipment.....
