Author Topic: help please battery change radio code cdr2005  (Read 6204 times)
markspark
  • Bolton
« on: 18 December 2011, 13:53:16 »
Hi all as the title says im going to change the battery on my 2001 2.2dti it has the cdr 2005 radio fitted and i dont have the code for it will i loose the code by changing the battery if so what method can i use to save the code
TIA
Re: help please battery change radio code cdr2005
« Reply #1 on: 18 December 2011, 13:55:07 »
Likely, unless previous owner has disabled the code (unlikely).
Carpass from dealer, assuming its the original.
markspark
  • Bolton
« Reply #2 on: 18 December 2011, 13:56:40 »
bummer :(
markspark
  • Bolton
« Reply #3 on: 18 December 2011, 13:57:43 »
is there a way to disable prior to removal
« Reply #4 on: 18 December 2011, 13:58:40 »
Indeed. But you need the code to disable it ;)
It would be a pretty pointless security device otherwise ;D
markspark
  • Bolton
« Reply #5 on: 18 December 2011, 14:02:32 »
full of good news aint you TB  ;D
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #6 on: 18 December 2011, 14:06:14 »
Unlike the carpass which may not even show the correct radio, I can certainly help with decoding of that model
http://www.dndservices.co.uk/Vauxhall-CDR-2005-(E)-code.html
Radio & Decoding Technician
markspark
  • Bolton
« Reply #7 on: 18 December 2011, 14:10:25 »
im doing a 600mile round trip up scotland setting off in the morning i need my music lol
would this work if i put battery charger on pos and neg somewhere other than the battery then change the battery what you think ??
markspark
  • Bolton
« Reply #8 on: 18 December 2011, 14:11:54 »
if i do loose the code Dave it will be sent to you for you to work your magic
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #9 on: 18 December 2011, 14:12:28 »
just thinking outloud here  :o but wouldnt it be at all possible to connect say a charger/booster or even another battery onto the the original battery clamps ? then when you disconnect the original battery the back up you have used will still put electric through therefore keeping everything live and working untill new battery is fitted  :-\  or would having the the back up and a new battery cause an excessive voltage and fry things  :-\
as i said just thinking outloud  :y
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #10 on: 18 December 2011, 14:14:19 »
Not advisable --
Many garages used to use a similar device called a codesaver that was plugged into the cigarette lighter socket, but for some unknown reason this used to interfere with SRS systems and could even case airbags to deploy, which is why this practice is no longer followed.
fiend61
  • york
  • each to their own
« Reply #11 on: 18 December 2011, 14:19:55 »
ahhh ok dave just wondered if it was feasible  ;)
really dont want to deploy airbags just to save a radio code  ::)
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #12 on: 18 December 2011, 14:22:36 »
I saw the aftermath at a Volvo garage recently, where something similar had been done and airbags deployed.
I dread to think of the costs involved, as including the side curtains, we counted 11 deployments !!
 :-X
« Reply #13 on: 18 December 2011, 14:23:32 »
Yep, done that with no probs ;)
« Reply #14 on: 18 December 2011, 14:25:42 »
Me too. ;)
