Author Topic: possible problem 1st-2nd gear auto 2.6v6 52 plate  (Read 4998 times)
GLENNY BOY
  • dartford
    • cd 2.6 auto v6 2002
« on: 18 December 2011, 16:45:52 »
maybe its just me but sometimes on pulloff it takes an age to drop into 2nd gear it goes up to 35000 rpm to change into 2nd but other times ok is it just me also does mine have a 5 speed auto box or 4 speed auto theres no warning lights on its only done 78000 miles thanks glenn :y :y
Re: possible problem 1st-2nd gear auto 2.6v6 52 plate
« Reply #1 on: 18 December 2011, 17:01:50 »
Normal with a cold engine
GLENNY BOY
  • dartford
« Reply #2 on: 18 December 2011, 17:10:42 »
its not a cold engine when this happens  :y
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
« Reply #3 on: 18 December 2011, 17:14:25 »
mine does it sometimes,but i put it down to how i accelorate ;)
GLENNY BOY
  • dartford
« Reply #4 on: 18 December 2011, 17:20:23 »
oh right so its not me ::) but why does it do it when driving normal :y :y
noel
  • frome somerset
« Reply #5 on: 18 December 2011, 17:29:25 »
??? i drive mine hard as rule so dont really bother me  ;D ;D ;).But thats not to say you may have a problem  :-\
GLENNY BOY
  • dartford
« Reply #6 on: 18 December 2011, 17:50:22 »
what problem could it be then  ???
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« Reply #7 on: 18 December 2011, 19:33:48 »
try changing autobox fluid
V8!!!!
noel
  • frome somerset
« Reply #8 on: 18 December 2011, 20:15:47 »
or check oil level in gearbox   :-\
Michael2.6
  • Bishop Auckland
    • Vauxhall Omega
« Reply #9 on: 18 December 2011, 20:49:14 »
Have you tried the auto box solenoids
Is there a thud when the box goes into 2nd gear ?
serek
  • huntingdon
    • 3.2 mv6
« Reply #10 on: 18 December 2011, 21:50:12 »
top up oil first  :y
« Reply #11 on: 18 December 2011, 21:54:12 »
Service auto box every 60k.
Whats the sift quality like? Any revving? Loss of drive or thumping?
GLENNY BOY
  • dartford
« Reply #12 on: 19 December 2011, 23:03:24 »
do you have to go to a main dealer for autobox oil change :y :y yes to  all what you said i think there is a little jolt when changing gear very very minor  can hardly feel it not sure  ???
« Reply #13 on: 19 December 2011, 23:19:01 »
Dealer is the last place you go for work on a car. Parts, with a trade club card, possibly. Service dept...   break  in  NO   ! Although there are some decent ones about, odds are against even half decent service.
You'll get ..... ooh they are sealed for life, you need a torque converter, valve body, ecu, new box, ah none of those have fixed it....an insignia sir?
IMO service the auto box fluid with decent dex3 ATF and change the 1st to 2nd solenoid while the sumps are off.
« Reply #14 on: 20 December 2011, 09:53:58 »
If the autobox itself is delaying changes for some (mechanical or hydraulic) reason there will be fault codes stored in the ECU, so worth getting it read for codes as a first step, IMHO.
Pulling away with gentle throttle and a fully warmed up engine I would expect it to slot into 2nd well under 3000 RPM but the problem with diagnosing problems like this is that we don't all have the same definition of "gentle throttle". ;)
