Author Topic: Cam gasket on v6  (Read 3554 times)
gareth.
  • Endor forest, South Wales
    • 2.5 v6 cdx leather
Cam gasket on v6
« on: 19 December 2011, 17:08:47 »
Got a nasty leak on drivers side cam gasket, I looked at the guide and it seemed to finish halfway through? is it just me? :) (there was only one page, I checked that one!)
If it's not broken, don't fix it.
martin42
Re: Cam gasket on v6
« Reply #1 on: 19 December 2011, 18:00:06 »
guide is correct and only 1 page,refitting is the reversal of removal,its not that hard to do,but will be worth doing both banks at the sametime  :y
aitch015
  • catterick north yorks
    • 2001 2.6 elite
« Reply #2 on: 19 December 2011, 21:27:39 »
I done mine at the weekend mate. I would have been lost without the forum guides. Even when i got confused or stuck i found the answer using a different search criteria. I am by no means a confident mechanic,so i gave them a good read and used little bags and labels for the bolts and bits. Most of the work i had to do was cleaning the breathers,which on mine were really clogged up with oily mayanaise like gunk,and the plug wells which were swimming in oil. I found that putting it back together is a lot easier than taking it apart. :y
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #3 on: 19 December 2011, 21:41:33 »
When I did mine on my last omega I used a piece of cardboard to store the bolts, etc in (by pushing them through the cardboard) and you were able to label them appropriately, plus keep them all in one place  :y
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #4 on: 19 December 2011, 21:42:46 »
Oh, I should add that I didn't think of that all by myself  :-[
Can't remember now where I saw it tho, but it definitely works.
« Reply #5 on: 19 December 2011, 22:00:29 »
a idea often used to keep valves in the correct order  ;) ;)
gareth.
« Reply #6 on: 20 December 2011, 00:23:04 »
Cheers I will get them priced up at Vx tomorrow, job for the weekend. (Just kidding, the missus and kids won't be too pleased) :y
« Reply #7 on: 20 December 2011, 00:30:55 »
welcome to either pop up to me, or I'll come down your way, and give a hand :y
gareth.
« Reply #8 on: 20 December 2011, 00:35:45 »
Would you be willing to have a look if I run into some trouble? I'll pay you of course.
« Reply #9 on: 20 December 2011, 00:37:30 »
edited, intended for PM
gareth.
« Reply #10 on: 20 December 2011, 00:39:10 »
I wanted a picture of the gaskets in place, does anyone have one?
I am pretty confident of doing the job but want a back up plan just incase. :)
Do I have to go over the bare metal work with a flat blade to get any old gasket off? How critical is getting it clean?  :)
marrus69
  • bracknell
    • 52 mv6 3.2
« Reply #11 on: 20 December 2011, 03:22:54 »
as im waiting for my gaskets to turn up ,is  thier any thing that needs to be tork down arfter.in a strange way im looking forward to doing it,if thay dont turn up tuesday in on the phone.
« Reply #12 on: 20 December 2011, 10:25:20 »
Cam covers need to be torqued down to 8nm only.you will need a torque wrench which goes down to that figure before you do the job. ;)
Surfaces on heads and camcovers need to be have traces old sealant removed before reassembly.Also dont forget to remove the old O rings from underneath the bolt holes.They probably wont resemble O rings, more like hard/flat plastic washers which need to be prised out with a small screwdriver or similar.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #13 on: 20 December 2011, 13:28:48 »
Gareth, well done on having the nuts to do this yourself. I'm learning everytime I get on here. And next time something goes wrong I'll be giving it a bash myself ;) I'm nowhere near confident to do cam cover gasket but i'll get there ;)
By the way, talking of gaskets, there is a lot of talk about head gasket going. on my understanding that the ''gasket'' is the seal then what exactly do the ''heads'' do?
cheers :)
RIP Paul Lovejoy
« Reply #14 on: 20 December 2011, 16:27:38 »
cheers :)
The Cylinder heads sit directly above the pistons - with a chamber (for want of a better expression) above each piston - each chamber has a set of valves (inlet and exhaust) which open/close in sequence with the piston, as part of the combustion process, allowing it to suck air in from the inlet manifold, ignite the air/fuel mixture, causing the piston to be forced back down, and the bi-product released through the exhaust valves > manifold, before the cycle starts again...
« Last Edit: 20 December 2011, 16:29:16 by JamesV6CDX »
